[Live-demo] Does your application work on the click2try GISVM?
Cameron Shorter cameron.shorter at lisasoft.com
Tue Oct 13 16:11:02 EDT 2009
Thanks Aneel, this is looking very promising.
I suspect the remaining issues are non-events. I'm CCing the live demo
list as there will be people there who should be able to confirm  that.
Aneel wrote:
> Hello Cameron,
> We have fixed the following issues in new VM called "osgeo-gisvm20-25":
> Fixed Issues
> 1. #497: click2try - no way svn update files in gisvm/bin/
> 2. #495: click2try VM user/password should be same as LiveDVD
> 3. #494: Remove screen saver on click2try image
> 4. There are no icons for deegree
> 5. There is no mapserver icon
> 6. The "Start Mapnik & TileLite" icon is missing
> 7. There is no "MapTiler" icon
> 8. The desktop icon using launchassist.sh is rigged specifically to the
> password user on the sudo command. That's probably why it didn't work.
> Pending issues:
> Issue1:
> Launching /usr/bin/mapnik_start_tilelite.sh
> [TileLite Debug] --> Using mapfile:
> '/usr/local/share/mapnik/demo/population.xml'
> Traceback (most recent call last):
>   File "/usr/local/bin/liteserv.py", line 120, in <module>
>     from tilelite import Server
>   File "/usr/local/lib/python2.6/dist-packages/tilelite.py", line 12, in
> <module>
>     import mapnik
> ImportError: No module named mapnik
> Issue2: (GeoNetwork - it doesn't work)
> Launching /usr/lib/geonetwork/bin/start-geonetwork.sh
> rm: cannot remove `logs/*request.log*': No such file or directory
> rm: cannot remove `logs/output.log': No such file or directory
> mv: cannot stat `logs/geonetwork.log.*': No such file or directory
> mv: cannot stat `logs/intermap.log.*': No such file or directory
> mv: cannot stat `logs/geoserver.log.*': No such file or directory
> Developer can test latest GISVM ( osgeo-gisvm20-25) and help us to fix
> the remaining issue. Please let us know the changes to fix them
> permanently.
> Regards,
> Aneel
> click2try
> On Tue, 2009-10-13 at 21:18 +1100, Cameron Shorter wrote:
>> It seems Aneel has found a work around:
>> Aneel wrote:
>> I have re-executed the  install_geonetwork.sh script as cameron
>> suggested but still issue persists. I have resolved this by adding
>> "user" in admin group & given sudoer privileges to admin group.
>> Ricardo Pinho wrote:
>>> Hi Jeroen,
>>>> 1. GeoNetwork - it doesn't work
>>> Are you on this issue?
>>> I must ask you to help the click2try team to get Geonetwork on this
>>> version of LiveDVD.
>>> Thank you,
>>> Ricardo Pinho
>>> *De:* Aneel <aneel.r at tecnics.com>
>>> *Para:* Cameron Shorter <cameron.shorter at lisasoft.com>
>>> *Cc:* Tom Callaghan <tom.callaghan at presage-tech.com>; Arun Sharma
>>> Tecnics <arun.s at tecnics.com>; "live-demo at lists.osgeo.org"
>>> <live-demo at lists.osgeo.org>
>>> *Enviadas:* Seg, Outubro 12, 2009 5:59:15 PM
>>> *Assunto:* Re: [Live-demo] Does your application work on the click2try
>>> GISVM?
>>> Hello Cameron and Osgeo team,
>>> After screening all the mails till now , we have listed out the issues
>>> mentioned by osgeo members.
>>> Some of the issues we have already fixed in multilayer gisvm. They are
>>> 1. There are no icons for deegree
>>> 2. There is no mapserver icon
>>> 3. The "Start Mapnik & TileLite" icon is missing
>>> 4. There is no "MapTiler" icon
>>> 5. #494: Remove screen saver on click2try image
>>> 6. #495: click2try VM user/password should be same as LiveDVD
>>> Pending issues to be fixed and we are trying to fix it. If you have
>>> any information please let us know
>>> 2. The desktop icon using launchassist.sh is rigged specifically to the
>>> Developers who are re-testing, can do modification as they want on
>>> click2try image (Vm) and please let us know the changes to fix them
>>> permanently.
>>> How to access gisvm:
>>> URL http://www.click2try.com
>>> user id  : osgeo
>>> password : livedemo
>>> Once logged in, navigate to My Dashboard -> Applications Manager.  You will see
>>> a VM named osgeo-gisvm20-2.  Hilite that and click the red LAUNCH button. This will connect you to the VM
>>> Gnome Desktop user credentials:
>>> user id      : user
>>> password : user
>>> One another point, this running vm is build using
>>> "branches/arramagong_2" and please find below errors (got while
>>> Installation)
>>> Error1:
>>> cp: omitting directory `/usr/local/share/grass/spearfish60/user1/dbf'
>>> cp: omitting directory `/usr/local/share/grass/nc_spm_08/user1/cats'
>>> cp: omitting directory `/usr/local/share/grass/nc_spm_08/user1/cell'
>>> cp: omitting directory `/usr/local/share/grass/nc_spm_08/user1/cell_misc'
>>> cp: omitting directory `/usr/local/share/grass/nc_spm_08/user1/cellhd'
>>> cp: omitting directory `/usr/local/share/grass/nc_spm_08/user1/colr'
>>> cp: omitting directory `/usr/local/share/grass/nc_spm_08/user1/colr2'
>>> cp: omitting directory `/usr/local/share/grass/nc_spm_08/user1/dbf'
>>> cp: omitting directory `/usr/local/share/grass/nc_spm_08/user1/fcell'
>>> cp: omitting directory `/usr/local/share/grass/nc_spm_08/user1/g3dcell'
>>> cp: omitting directory `/usr/local/share/grass/nc_spm_08/user1/hist'
>>> cp: omitting directory `/usr/local/share/grass/nc_spm_08/user1/vector'
>>> cp: omitting directory `/usr/local/share/grass/nc_spm_08/user1/windows'
>>> Adding user `user' to group `users' ...
>>> Adding user user to group users
>>> Done.
>>> 2009-10-09 17:22:41
>>> URL:http://svn.osgeo.org/grass/grass/trunk/gui/icons/grass-48x48.png
>>> [2407/2407] -> "grass-48x48.png" [1]
>>> Finished installing GRASS 6.4.
>>> Error2:
>>> Warning messages:
>>> 1: In getDependencies(pkgs, dependencies, available, lib) :
>>>   package 'pkgDepTools' is not available
>>> 2: In getDependencies(pkgs, dependencies, available, lib) :
>>>   package 'Rgraphviz' is not available
>>>> q()
>>> Error3:
>>> https://svn.osgeo.org/osgeo/livedvd/gisvm/branches/arramagong_2/doc/descriptions/maptiler_description.html:
>>> 2009-10-09 19:16:33 ERROR 404: Not Found.
>>> Note: Please do not shutdown testing vm.
>>> We will wait for your feedback.
>>> Regards
>>> Aneel
>>> On Mon, 2009-10-12 at 13:16 +0200, Eric Lemoine wrote:
>>>> On Mon, Oct 12, 2009 at 12:24 PM, Cameron Shorter
>>>> <cameron.shorter at lisasoft.com <mailto:cameron.shorter at lisasoft.com>> wrote:
>>>>> Eric,
>>>>> On the click2try VM, could you please:
>>>>>  svn update install_mapfish.sh
>>>> it looks like I don't have the permissions to svn upate
>>>> install_mapfish.sh in /usr/loca/share/gisvm/bin. Were you thinking
>>>> about something else?
>>>> Thanks,
>>>>>  sudo ./install_mapfish.sh 2&>1 tee /var/log/arramagong/install_mapfish.log
>>>>>  # Verify that mapfish works
>>>>> Eric Lemoine wrote:
>>>>>> 2009/10/10 Cameron Shorter <cameron.shorter at gmail.com <mailto:cameron.shorter at gmail.com>>:
>>>>>>> Tom tells me I can forward this email to the public live demo list now.
>>>>>>> So
>>>>>>> please reply to this list.
>>>>>> Hi
>>>>>> Mapfish isn't installed properly in the click2try virtual machine. The
>>>>>> virtual machine was installed before Hamish did an important change to
>>>>>> install_mapfish.sh it seems. What should we do?
>>>>>> Thanks,
>>>>> Cameron Shorter
>>>>> Geospatial Solutions Manager
>>>>> Tel: +61 (0)2 8570 5050
>>>>> Mob: +61 (0)419 142 254
>>>>> Think Globally, Fix Locally
>>>>> Geospatial Solutions enhanced with Open Standards and Open Source
>>>>> http://www.lisasoft.com
>>> Veja quais são os assuntos do momento no Yahoo! + Buscados: Top 10
>>> <http://br.rd.yahoo.com/mail/taglines/mail/*http://br.maisbuscados.yahoo.com/>
>>> - Celebridades
>>> <http://br.rd.yahoo.com/mail/taglines/mail/*http://br.maisbuscados.yahoo.com/celebridades/>
>>> - Música
>>> <http://br.rd.yahoo.com/mail/taglines/mail/*http://br.maisbuscados.yahoo.com/m%C3%BAsica/>
>>> - Esportes
>>> <http://br.rd.yahoo.com/mail/taglines/mail/*http://br.maisbuscados.yahoo.com/esportes/>
Cameron Shorter
More information about the Live-demo mailing list
