[Live-demo] Does your application work on the click2try GISVM?
Cameron Shorter cameron.shorter at lisasoft.com
Wed Oct 14 23:47:25 EDT 2009
Arun,
I've lost track of where geonetwork is up to. I think you had it fixed,
and Simon/Jeroen were just updating the automated script for future.
Simon, are you able to confirm this?
arun.s at tecnics.com wrote:
> Hello Cameron,
> After reviewing this mail , i think there is something more to be done
> to fix this in click2try vm (not sure).
> It will be good if (any) steps we need to do on click2try to fix this
> issue then please inform us.
> FYI , we have already applied the steps metioned by Jeron on currently
> running vm.
> Arun Sharma
> Click2try
> *From*: "Simon Pigot" <Simon.Pigot at csiro.au>
> *Sent*: Thursday, October 15, 2009 6:33 AM
> *To*: "Cameron Shorter" <cameron.shorter at lisasoft.com>
> *Subject*: Re: [Live-demo] Does your application work on the click2try
> GISVM?
> What puzzles me about all this is that the changes Jeroen has made to
> the shortcut scripts were actually the way in which the shortcut scripts
> were originally submitted!
> Cameron, the chown command is in the install_geonetwork.sh already!
> The problems seem to have been caused by a decision someone made to
> change the uid/gid of user/password (when? how? why?) - is it still
> necessary to run the scripts with a sudo to user?
> Cheers,
> Simon
> Cameron Shorter wrote:
> > Jeroen,
> > I hope that we can apply your fixes to the geonetwork install scripts.
> > If you have not updated the install_geonetwork.sh , can you please
> > describe the issue and fix in the issue tracker, so that we can update
> > it before we go through the next release cycle.
> http://trac.osgeo.org/osgeo/query?group=status&component=LiveDVD&order=priority
> > Jeroen Ticheler wrote:
> >> Hi Aneel,
> >> These are the changes I did:
> >> from the root of the geonetwork application:
> >> sudo chown -R user:user *
> >> In the shortcuts that start and stop GeoNetwork I removed the first
> >> part of the command, just leaving the part:
> >> /usr/lib/geonetwork/bin/start-geonetwork.sh
> >> or
> >> /usr/lib/geonetwork/bin/stop-geonetwork.sh
> >> That's all.
> >> Ciao,
> >> Jeroen
> >> ____________________________________________________
> >> Jeroen Ticheler
> >> De Braakweg 12a
> >> 7524 PH Enschede
> >> Tel/Fax: +31 (0)53 7370049
> >> Mobile: +31 (0)6 81286572
> >> http://www.ticheler.net
> >> Please consider the environment before printing this email.
> >> On Oct 14, 2009, at 1:11 PM, Aneel wrote:
> >>> Hello Jeroen,
> >>> Please give us the steps you did to fix these issues. Whatever you
> doing
> >>> is specific to particular instance only. We have to fix them at
> >>> application level to make permanent.
> >>> Regards
> >>> Aneel
> >>> click2try
> >>> On Wed, 2009-10-14 at 13:05 +0200, Jeroen Ticheler wrote:
> >>>> Last thing, I also fixed the start and stop shortcuts. They should
> >>>> point directly to the start and stop scripts and not go through the
> >>>> launchhelper script.
> >>>> Greetings,
> >>>> Jeroen
> >>>> On Oct 14, 2009, at 12:46 PM, Aneel wrote:
> >>>>> Hello Jeroen,
> >>>>> Maintenance and bug fix activity is going on click2try-GISVM. Please
> >>>>> don't try the GISVM on click2try for some time.. Once we have
> done with
> >>>>> maintenance activity, we will post update on this mailing list.
> >>>>> Regards
> >>>>> Aneel
> >>>>> click2try
> >>>>> On Wed, 2009-10-14 at 12:41 +0200, Jeroen Ticheler wrote:
> >>>>>> Hi Tom,
> >>>>>> I tried again several times today. I got some steps further, but
> >>>>>> can't
> >>>>>> get on to the desktop :-( I use "user/user" as account/pw but
> then I
> >>>>>> get an error as shown on the screenshot. Is there a way to use SSH?
> >>>>>> Kind regards,
> >>>>>> Jeroen
> >>>>>> Jeroen Ticheler
> >>>>>> De Braakweg 12a
> >>>>>> 7524 PH Enschede
> >>>>>> On Oct 14, 2009, at 1:22 AM, Tom Callaghan wrote:
> >>>>>>> Hi Jaroen,
> >>>>>>> Maybe I can help you with your connection issues. The message
> >>>>>>> "Public Internet Access: Yes, Not available" refers to something
> >>>>>>> that has not yet been set up for this VM. This is not a
> problem and
> >>>>>>> you should still be able to access the VM. When you attempted to
> >>>>>>> connect, had you highlighted the VM osgeo-gisvm20-25 and click2ed
> >>>>>>> the LAUNCH button? If so, what happens? Do you see a light purple
> >>>>>>> screen with a progress bar across the top? Do you receive a
> message
> >>>>>>> for installing a click2try java applet? Does a frame with a page
> >>>>>>> not found appear on the left side of the screen with a title bar
> >>>>>>> "quickstart guide"?
> >>>>>>> Tom
> >>>>>>> From: Jeroen Ticheler [mailto:Jeroen at Ticheler.net]
> >>>>>>> Sent: Tuesday, October 13, 2009 5:41 PM
> >>>>>>> To: Aneel
> >>>>>>> Cc: Cameron Shorter; Ricardo Pinho; Tom Callaghan; Arun Sharma
> >>>>>>> Tecnics
> >>>>>>> Subject: Re: [Live-demo] Does your application work on the
> click2try
> >>>>>>> GISVM?
> >>>>>>> Hi Aneel,
> >>>>>>> I tried to connect and have a look. I can't get access, maybe
> >>>>>>> because someone else is using the VM, is that correct? I read
> >>>>>>> "Public Internet Access: Yes, Not available" and I see one user
> >>>>>>> online.
> >>>>>>> Concerning the problem, the first two lines are normal for a very
> >>>>>>> first time startup. The following three lines are not and indicate
> >>>>>>> that the permissions of the account running the application don't
> >>>>>>> allow writing to the logs directory. Most likely the same is true
> >>>>>>> for some other directories that GeoNetwork needs to be able to
> write
> >>>>>>> to. I suggest reviewing the privileges of the process owner to
> >>>>>>> ensure that write privileges are given to the GeoNetwork
> application
> >>>>>>> folders.
> >>>>>>> Let me know if I can help further.
> >>>>>>> Kind regards,
> >>>>>>> Jeroen
> >>>>>>> ps. I will be on my way to Sydney from Thursday morning onwards
> >>>>>>> (Amsterdam time zone).
> >>>>>>> On Oct 13, 2009, at 8:54 PM, Aneel wrote:
> >>>>>>> Issue2: (GeoNetwork - it doesn't work)
> >>>>>>> Launching /usr/lib/geonetwork/bin/start-geonetwork.sh
> >>>>>>> rm: cannot remove `logs/*request.log*': No such file or directory
> >>>>>>> rm: cannot remove `logs/output.log': No such file or directory
> >>>>>>> mv: cannot stat `logs/geonetwork.log.*': No such file or directory
> >>>>>>> mv: cannot stat `logs/intermap.log.*': No such file or directory
> >>>>>>> mv: cannot stat `logs/geoserver.log.*': No such file or directory
Cameron Shorter
Geospatial Solutions Manager
Tel: +61 (0)2 8570 5050
Mob: +61 (0)419 142 254
Think Globally, Fix Locally
Geospatial Solutions enhanced with Open Standards and Open Source
http://www.lisasoft.com
More information about the Live-demo mailing list
