Cameron, > If a fix is found in udig, are you able to update it afterwards? Ie, > after the press release goes out? > If so, I propose to send out the press release in 60 minutes at 9:30am > Sydney time. Yes. We can change it after publishing. I would say it is safe to publish the press release. Tom
