[Live-demo] [About python issue] Does your application work on the
 click2try GISVM?
    Arun Sharma Tecnics
    arun.s at tecnics.com
    Fri Oct 16 08:07:15 EDT 2009
Hello Dane,
Could you please help us by trying again "python" command from new
instance vm rather then using existing '20-74'. ?
Arun Sharma
Click2try
Dane Springmeyer wrote:
> Running `strace python` gives an Illegal Instruction:
> http://dpaste.com/107722/
> I wonder if the read-only user mode is the culprit.
> Dane
> On Oct 15, 2009, at 9:51 AM, Dane Springmeyer wrote:
>> I just tried the latest VM '20-74' and now see a Segmentation Fault
>> when running the default python.
>> Open a terminal and type 'python' and this is what you get:
>> user at osgeo-gisvm20-74:~$ python
>> Segmentation fault
>> but python2.5 works:
>> user at osgeo-gisvm20-74:~$ python2.5
>> >>> # all good...
>> Really odd, I've never seen a segfault like this with python after
>> just starting the interpreter.
>> Dane
>> On Oct 15, 2009, at 9:00 AM, Aneel wrote:
>>> Hello OSGeo Team,
>>> We have fixed issues and latest click2try-GISVM (osgeo-gisvm20-74)
>>> is available for testing at www.click2try.com.
>>> <http://www.click2try.com>
>>> Know Issue: (Reported to Jody)
>>> /usr/bin/udig: line 29:  3026 Segmentation fault
>>> $PRGDIR/udig_internal -data ~/uDigWorkspace $@
>>> Please let us know if any more issues after testing.
>>> Thanks & Regards
>>> Aneel
>>> click2try
>>> On Thu, 2009-10-15 at 12:32 +0530, Aneel wrote:
>>>> Hello Team,
>>>> Maintenance and bug fix activity is going on click2try-GISVM. Please
>>>> don't try the GISVM on click2try for some time. Once we are done with
>>>> maintenance activity, we will post update on this mailing list.
>>>> Regards
>>>> Aneel
>>>> On Thu, 2009-10-15 at 14:47 +1100, Cameron Shorter wrote:
>>>> > Arun,
>>>> > I've lost track of where geonetwork is up to. I think you had it fixed,
>>>> > and Simon/Jeroen were just updating the automated script for future.
>>>> > Simon, are you able to confirm this?
>>>> > arun.s at tecnics.com <mailto:arun.s at tecnics.com> wrote:
>>>> > > Hello Cameron,
>>>> > > After reviewing this mail , i think there is something more to be done
>>>> > > to fix this in click2try vm (not sure).
>>>> > > It will be good if (any) steps we need to do on click2try to fix this
>>>> > > issue then please inform us.
>>>> > > FYI , we have already applied the steps metioned by Jeron on currently
>>>> > > running vm.
>>>> > > Arun Sharma
>>>> > > Click2try
>>>> > > *From*: "Simon Pigot" <Simon.Pigot at csiro.au <mailto:Simon.Pigot at csiro.au>>
>>>> > > *Sent*: Thursday, October 15, 2009 6:33 AM
>>>> > > *To*: "Cameron Shorter" <cameron.shorter at lisasoft.com <mailto:cameron.shorter at lisasoft.com>>
>>>> > > *Subject*: Re: [Live-demo] Does your application work on the click2try
>>>> > > GISVM?
>>>> > > What puzzles me about all this is that the changes Jeroen has made to
>>>> > > the shortcut scripts were actually the way in which the shortcut scripts
>>>> > > were originally submitted!
>>>> > > Cameron, the chown command is in the install_geonetwork.sh already!
>>>> > > The problems seem to have been caused by a decision someone made to
>>>> > > change the uid/gid of user/password (when? how? why?) - is it still
>>>> > > necessary to run the scripts with a sudo to user?
>>>> > > Cheers,
>>>> > > Simon
>>>> > > > Jeroen,
>>>> > > > I hope that we can apply your fixes to the geonetwork install scripts.
>>>> > > > If you have not updated the install_geonetwork.sh , can you please
>>>> > > > describe the issue and fix in the issue tracker, so that we can update
>>>> > > > it before we go through the next release cycle.
>>>> > > http://trac.osgeo.org/osgeo/query?group=status&component=LiveDVD&order=priority <http://trac.osgeo.org/osgeo/query?group=status&component=LiveDVD&order=priority>
>>>> > > > Jeroen Ticheler wrote:
>>>> > > >> Hi Aneel,
>>>> > > >> These are the changes I did:
>>>> > > >> from the root of the geonetwork application:
>>>> > > >> sudo chown -R user:user *
>>>> > > >> In the shortcuts that start and stop GeoNetwork I removed the first
>>>> > > >> part of the command, just leaving the part:
>>>> > > >> /usr/lib/geonetwork/bin/start-geonetwork.sh
>>>> > > >> or
>>>> > > >> /usr/lib/geonetwork/bin/stop-geonetwork.sh
>>>> > > >> That's all.
>>>> > > >> Ciao,
>>>> > > >> Jeroen
>>>> > > >> ____________________________________________________
>>>> > > >> Jeroen Ticheler
>>>> > > >> De Braakweg 12a
>>>> > > >> 7524 PH Enschede
>>>> > > >> Tel/Fax: +31 (0)53 7370049
>>>> > > >> Mobile: +31 (0)6 81286572
>>>> > > >> http://www.ticheler.net
>>>> > > >> Please consider the environment before printing this email.
>>>> > > >> On Oct 14, 2009, at 1:11 PM, Aneel wrote:
>>>> > > >>> Hello Jeroen,
>>>> > > >>> Please give us the steps you did to fix these issues. Whatever you
>>>> > > doing
>>>> > > >>> is specific to particular instance only. We have to fix them at
>>>> > > >>> application level to make permanent.
>>>> > > >>> Regards
>>>> > > >>> Aneel
>>>> > > >>> click2try
>>>> > > >>> On Wed, 2009-10-14 at 13:05 +0200, Jeroen Ticheler wrote:
>>>> > > >>>> Last thing, I also fixed the start and stop shortcuts. They should
>>>> > > >>>> point directly to the start and stop scripts and not go through the
>>>> > > >>>> launchhelper script.
>>>> > > >>>> Greetings,
>>>> > > >>>> Jeroen
>>>> > > >>>> On Oct 14, 2009, at 12:46 PM, Aneel wrote:
>>>> > > >>>>> Hello Jeroen,
>>>> > > >>>>> don't try the GISVM on click2try for some time.. Once we have
>>>> > > done with
>>>> > > >>>>> Regards
>>>> > > >>>>> Aneel
>>>> > > >>>>> click2try
>>>> > > >>>>> On Wed, 2009-10-14 at 12:41 +0200, Jeroen Ticheler wrote:
>>>> > > >>>>>> Hi Tom,
>>>> > > >>>>>> I tried again several times today. I got some steps further, but
>>>> > > >>>>>> can't
>>>> > > >>>>>> get on to the desktop :-( I use "user/user" as account/pw but
>>>> > > then I
>>>> > > >>>>>> get an error as shown on the screenshot. Is there a way to use SSH?
>>>> > > >>>>>> Kind regards,
>>>> > > >>>>>> Jeroen
>>>> > > >>>>>> Jeroen Ticheler
>>>> > > >>>>>> De Braakweg 12a
>>>> > > >>>>>> 7524 PH Enschede
>>>> > > >>>>>> On Oct 14, 2009, at 1:22 AM, Tom Callaghan wrote:
>>>> > > >>>>>>> Hi Jaroen,
>>>> > > >>>>>>> Maybe I can help you with your connection issues. The message
>>>> > > >>>>>>> "Public Internet Access: Yes, Not available" refers to something
>>>> > > >>>>>>> that has not yet been set up for this VM. This is not a
>>>> > > problem and
>>>> > > >>>>>>> you should still be able to access the VM. When you attempted to
>>>> > > >>>>>>> connect, had you highlighted the VM osgeo-gisvm20-25 and click2ed
>>>> > > >>>>>>> the LAUNCH button? If so, what happens? Do you see a light purple
>>>> > > >>>>>>> screen with a progress bar across the top? Do you receive a
>>>> > > message
>>>> > > >>>>>>> for installing a click2try java applet? Does a frame with a page
>>>> > > >>>>>>> not found appear on the left side of the screen with a title bar
>>>> > > >>>>>>> "quickstart guide"?
>>>> > > >>>>>>> Tom
>>>> > > >>>>>>> From: Jeroen Ticheler [mailto:Jeroen at Ticheler.net]
>>>> > > >>>>>>> Sent: Tuesday, October 13, 2009 5:41 PM
>>>> > > >>>>>>> To: Aneel
>>>> > > >>>>>>> Cc: Cameron Shorter; Ricardo Pinho; Tom Callaghan; Arun Sharma
>>>> > > >>>>>>> Tecnics
>>>> > > >>>>>>> Subject: Re: [Live-demo] Does your application work on the
>>>> > > click2try
>>>> > > >>>>>>> GISVM?
>>>> > > >>>>>>> Hi Aneel,
>>>> > > >>>>>>> I tried to connect and have a look. I can't get access, maybe
>>>> > > >>>>>>> because someone else is using the VM, is that correct? I read
>>>> > > >>>>>>> "Public Internet Access: Yes, Not available" and I see one user
>>>> > > >>>>>>> online.
>>>> > > >>>>>>> Concerning the problem, the first two lines are normal for a very
>>>> > > >>>>>>> first time startup. The following three lines are not and indicate
>>>> > > >>>>>>> that the permissions of the account running the application don't
>>>> > > >>>>>>> allow writing to the logs directory. Most likely the same is true
>>>> > > >>>>>>> for some other directories that GeoNetwork needs to be able to
>>>> > > write
>>>> > > >>>>>>> to. I suggest reviewing the privileges of the process owner to
>>>> > > >>>>>>> ensure that write privileges are given to the GeoNetwork
>>>> > > application
>>>> > > >>>>>>> folders.
>>>> > > >>>>>>> Let me know if I can help further.
>>>> > > >>>>>>> Kind regards,
>>>> > > >>>>>>> Jeroen
>>>> > > >>>>>>> ps. I will be on my way to Sydney from Thursday morning onwards
>>>> > > >>>>>>> (Amsterdam time zone).
>>>> > > >>>>>>> On Oct 13, 2009, at 8:54 PM, Aneel wrote:
>>>> > > >>>>>>> Issue2: (GeoNetwork - it doesn't work)
>>>> > > >>>>>>> Launching /usr/lib/geonetwork/bin/start-geonetwork.sh
>>>> > > >>>>>>> rm: cannot remove `logs/*request.log*': No such file or directory
>>>> > > >>>>>>> rm: cannot remove `logs/output.log': No such file or directory
>>>> > > >>>>>>> mv: cannot stat `logs/geonetwork.log.*': No such file or directory
>>>> > > >>>>>>> mv: cannot stat `logs/intermap.log.*': No such file or directory
>>>> > > >>>>>>> mv: cannot stat `logs/geoserver.log.*': No such file or directory
>>>> Live-demo mailing list
>>>> Live-demo at lists.osgeo.org <mailto:Live-demo at lists.osgeo.org>
>>>> http://lists.osgeo.org/mailman/listinfo/live-demo
URL: http://lists.osgeo.org/pipermail/live-demo/attachments/20091016/aef1a01d/attachment-0001.html
More information about the Live-demo
