[Live-demo] Re: Dropbox on GISVM for script sharing
Cameron Shorter cameron.shorter at lisasoft.com
Wed Sep 2 03:53:53 EDT 2009
My hope is that we can use dropbox, (or rsync+server or similar), to
syncronise all directories where applications are installed.
Ie:
/usr
/etc
/home
etc.
It is of little value to use dropbox for the install_<project>.sh
scripts, which as hamish points out is much better handled by
subversion, as we are doing already.
Hamish wrote:
> Ricardo wrote:
>> I really think that we should implement a synchronized
>> folder inside GISVM so that we could easily share and update
>> the install scripts we are making.
>> The idea is to use the multi-platform engine: Dropbox.
>> http://www.getdropbox.com/
> I have no problem with adding a dropbox per se, it's a fine idea.
> But for the script development specifically, IMO the most sane approach
> it to keep it in a single dedicated place.
> The whole point of SVN is to handle distributed source code management
> without it becoming fragmented and out of sync. Also the revision control
> and logs it gives are really really important when you are trying to
> untangle some bug at some point in the future when short term memory
> has faded. (everyone is supplying useful commit comments, yes? :)
> I would suggest to keep a single SVN repository (either hosted at OSGeo
> or at GISVM's server, I don't really care as long as we don't dilute
> focus*) and make sure that everyone has write access to it. Public access
> from the internet with no accountability log is a no-go. Simply too many
> moronic vandals out there to deal with. All anyone has to do to get write
> access on the OSGeo livedvd SVN is create yourself an OSGeo ID and let us
> know what it is, it's very easy to add people.
> [*] this is the "divide" part of "divide and conquer", it's a trap.
> Keep an up to date copy on the GISVM side with
>   svn checkout https://svn.osgeo.org/osgeo/livedvd/gisvm/trunk/ osgeo_scripts
> then keep it in sync with
>   cd osgeo_scripts
>   svn up
> If you wish to develop some here, develop some there, then merge the two
> later, there are other SCM systems such as Mercurial and Git which are
> very good at that. Subversion is geared to the single central host +
> multiple local development copies model.
> SCM is a wonderful wonderful thing and is well worth the learning curve.
> We should not abandon or nullify its best features. The payoff is huge,
> the pitfalls of not using it are many. made my point yet? :)
> cheers,
> Hamish
> Live-demo mailing list
> Live-demo at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/live-demo
Cameron Shorter
Geospatial Systems Architect
Tel: +61 (0)2 8570 5050
Mob: +61 (0)419 142 254
Think Globally, Fix Locally
Geospatial Solutions enhanced with Open Standards and Open Source
http://www.lisasoft.com
More information about the Live-demo mailing list
