[Live-demo] install_pgrouting.sh feedback
    Alex Mandel
    tech_dev at wildintellect.com
    Tue Sep  8 17:05:10 EDT 2009
Cameron Shorter wrote:
> During the pgrouting.sh install, I get the following scaring error
> message. So far, I didn't remove the following packages.
> I suspect that removing the files listed might be too drastic? And if
> they are removed, it should be done in the setdown.sh script. What are
> your thoughts?
> WARNING: The following essential packages will be removed.
> This should NOT be done unless you know exactly what you are doing!
>  apt libc6 (due to apt) libgcc1 (due to apt) libstdc++6 (due to apt)
>  base-files base-passwd (due to base-files) libpam-modules (due to
>  base-files) bash debianutils (due to bash) libncurses5 (due to bash)
>  bsdutils coreutils libacl1 (due to coreutils) libselinux1 (due to
>  coreutils) dash diff dpkg lzma (due to dpkg) e2fsprogs e2fslibs (due to
>  e2fsprogs) libblkid1 (due to e2fsprogs) libcomerr2 (due to e2fsprogs)
>  libss2 (due to e2fsprogs) libuuid1 (due to e2fsprogs) findutils grep
>  libpcre3 (due to grep) gzip hostname login libpam0g (due to login)
>  libpam-runtime (due to login) mktemp mount libsepol1 (due to mount)
>  libvolume-id1 (due to mount) ncurses-base ncurses-bin perl-base
>  python-minimal python2.6-minimal (due to python-minimal) sed
>  sysvinit-utils tar util-linux lsb-base (due to util-linux) tzdata (due to
>  util-linux) libslang2 (due to util-linux) zlib1g (due to util-linux)
> 0 upgraded, 0 newly installed, 1358 to remove and 0 not upgraded.
> 2 not fully installed or removed.
> After this operation, 2844MB disk space will be freed.
> You are about to do something potentially harmful.
> To continue type in the phrase 'Yes, do as I say!'
Ya apt-get auto-remove can get kinda dangerous sometimes, I think it
told me it wanted to get rid of python when I was doing the QGIS
install. Just comment out that line for now. As a note of caution we
should probably hard code removal of packages that you know are extra,
which is kinda hard since there are so many other apps.
Alex
More information about the Live-demo
