[Live-demo] script to install R,
Rpy2 and python depemdencies (needed by qgis plug-in)
Massimo Di Stefano
massimodisasha at yahoo.it
Tue Sep 8 17:11:08 EDT 2009
on ubuntu 9.04, tring to install py-qwt4 but it give me this log :
python-qwt4:
Depends from : python v.(<2.6), but will be installed v.
2.6.2-0ubuntu1
seems that the packages was maded using a different python version (2.5)
instead of python v.3.6
i don't kow how if only my buntu vm is affected by this problem, maybe
exists a work around i can try to google about it.
In the past i tried to install qwt and pyqwt from source using a
precise python executable to fix he problem.
Massimo.
Il giorno 08/set/09, alle ore 19:18, Alex Mandel ha scritto:
> Massimo Di Stefano wrote:
>> Hi,
>> I tried to finde what python packages are needed by the qgis plug-in
>> and what is needed to install some R packages.
>> The R-packages list come from the book :
>> http://www.amazon.com/Applied-Spatial-Data-Analysis-Use/dp/0387781706/ref=ntt_at_ep_dpi_1
>> i've not included the qgis plug-in, the user can easy do itself
>> (select
>> what he needs)
>> but maybe we can add the .qgis directory in the /home/user/ to have
>> already installed some plug-in, tell me what you think about.
>> (minor issue : ubuntu has a python dependencies problem, it is not
>> able
>> to install the pyQwt libraries,
>> so is not possible to have raster-profile and scattergram plug-in)
> At the request of the QGIS team I included python-qwt-qt4 in the QGIS
> script, does that one work for Jaunty?
> Alex
> Live-demo mailing list
> Live-demo at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/live-demo
More information about the Live-demo
