[Live-demo] enough time for one more project in Live DVD?
Etienne Dube
etdube at gmail.com
Wed Sep 9 11:38:22 EDT 2009
I know the feature freeze deadline is past, but if there still is time
we'd like to include GeoKettle (http://www.geokettle.org), a geospatial
ETL tool, in the FOSS4G Live DVD. Installed size is 95 MB; the only
dependency is a Java JRE, which already is present in the image.
The install script is attached, it was tested on the GISVM Xubuntu image
(everything seems to work fine).
Thanks,
Etienne
<cid:part1.06020606.08040107 at gmail.com>
#!/bin/sh
# Purpose: Installation of GeoKettle in Ubuntu
# Author: Etienne Dube <etdube (at) gmail.com>
# Based on uDig install script by
# Stefan Hansen.
# Copyright (c) 2009 GeoSOA research group, Laval University
# Licensed under the GNU LGPL.
# This program is free software; you can redistribute it and/or modify it
# under the terms of the GNU Lesser General Public License as published
# by the Free Software Foundation, either version 2.1 of the License,
# or any later version. This library is distributed in the hope that
# it will be useful, but WITHOUT ANY WARRANTY, without even the implied
# warranty of MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
# See the GNU Lesser General Public License for more details, either
# in the "LICENSE.LGPL.txt" file distributed with this software or at
# web page "http://www.fsf.org/licenses/lgpl.html".
# About:
# This script will install GeoKettle into Ubuntu
# A >=1.5.0 Java runtime (i.e. Sun JRE) is required for GeoKettle
# Running:
# sudo ./install_geokettle.sh
TMP="/tmp/geokettle_downloads"
INSTALL_FOLDER="/opt"
GEOKETTLE_FOLDER="$INSTALL_FOLDER/geokettle"
BIN="/usr/bin"
USER_NAME="user"
USER_HOME="/home/$USER_NAME"
## Setup things... ##
# check required tools are installed
if [ ! -x "`which wget`" ] ; then
echo "ERROR: wget is required, please install it and try again"
exit 1
fi
# create tmp folders
mkdir $TMP
cd $TMP
## Install Application ##
# get udig
if [ -f "geokettle-3.2.0-20090609-bin.zip" ]
then
echo "geokettle-3.2.0-20090609-bin.zip has already been downloaded."
else
wget "http://downloads.sourceforge.net/project/geokettle/geokettle/3.2.0-20090609/geokettle-3.2.0-20090609-bin.zip" -O geokettle-3.2.0-20090609-bin.zip
fi
# unpack it
unzip geokettle-3.2.0-20090609-bin.zip -d $TMP
# move the contents to /opt/geokettle
mv $TMP/geokettle-3.2.0-20090609-bin $GEOKETTLE_FOLDER
## Configure Application ##
# make shell scripts executable
chmod a+x $GEOKETTLE_FOLDER/*.sh
# Create desktop icon
# copy it into the udig folder
# FIXME: Desktop folder may be named differently in localized setups (if the language is not English)
echo "#!/usr/bin/env xdg-open" > $USER_HOME/Desktop/geokettle.desktop
echo "[Desktop Entry]" >> $USER_HOME/Desktop/geokettle.desktop
echo "Name=GeoKettle" >> $USER_HOME/Desktop/geokettle.desktop
echo "Exec=$GEOKETTLE_FOLDER/spoon.sh" >> $USER_HOME/Desktop/geokettle.desktop
echo "Path=$GEOKETTLE_FOLDER" >> $USER_HOME/Desktop/geokettle.desktop
echo "Icon=$GEOKETTLE_FOLDER/spoon.png" >> $USER_HOME/Desktop/geokettle.desktop
echo "Type=Application" >> $USER_HOME/Desktop/geokettle.desktop
echo "Categories=Application;" >> $USER_HOME/Desktop/geokettle.desktop
# make the desktop icon owned by $USER_NAME and executable
chown $USER_NAME:$USER_NAME $USER_HOME/Desktop/geokettle.desktop
chmod a+x $USER_HOME/Desktop/geokettle.desktop
More information about the Live-demo
