[Live-demo] deegree on alpha4
Judit Mays
mays at lat-lon.de
Mon Sep 14 09:15:10 EDT 2009
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
Hello list,
installation of deegree did not work with alpha4.
I have identified at least one problem: java-installation path changed
between this and the former version. My script did not check for the
Java location but simply assumed it to be the same as before. I will
change this with the next version of the script.
It could be helpful for deegree and other Java-dependant software to
have JAVA_HOME variable set globally.
Just to make sure I will change the deegree script so it sets JAVA_HOME
none the less.
I don't know about alpha5 yet as I can't download it:
mays at wharariki:~$ wget
http://download.osgeo.org/livedvd/ArramagongGISVM2009alpha5.7z
- --2009-09-14 15:07:02--
Auflösen des Hostnamen »download.osgeo.org«.... 198.202.74.218
Verbindungsaufbau zu download.osgeo.org|198.202.74.218|:80... verbunden.
HTTP Anforderung gesendet, warte auf Antwort... 404 Not Found
2009-09-14 15:07:03 FEHLER 404: Not Found.
Kind regards,
Judit
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.9 (GNU/Linux)
Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org
iEYEARECAAYFAkquQd4ACgkQ00HMccodrqXK8gCfdMlr5K2GdG6Gop7+4FhMwFD/
8T0An11yNI06kjI/xEEz3I4ISmlpdywF
=7eK1
-----END PGP SIGNATURE-----
More information about the Live-demo
