[Live-demo] please avoid chown user:user
Andrea Aime
aaime at opengeo.org
Fri Sep 18 05:24:06 EDT 2009
Stefan Hansen ha scritto:
> Hi all!
> I played in the last couple of days a bit with generating an ISO-image
> from the VM and ran into a few problems.
> One of them is that some install-scripts change the owner of some files
> outside $HOME to "user". Unfortunately this doesn't go well when you
> boot from the LiveDVD. The original "user" is deleted, when the ISO is
> generated, and a new user is created during the boot process (apparently
> that is the way things have to be). Files that belonged to the old
> "user" belong on the LiveDVD to the uid=1000, but the new user has the
> uid=999. Therefore, the new user cannot write these files and some
> applications won't work (so far I had problems with Geoserver and
> Degree, but I haven't tested all applications). So Instead of changing
> the owner of a file or directory, please keep root as owner and just
> change the access permissions. If you do so, please only change the
> write-permissions of a file only if you really, really have to. AFAIK
> everything writable is loaded into the memory, when you boot from the DVD.
The GeoServer data directory needs to be writable in order for GeoServer
to work.
By what you said all that I need to do is to change the script so that
all files are writable by everyone even if they are owned by root?
Something like "chmod a+w -R <data dir>"?
Cheers
Andrea
Andrea Aime
OpenGeo - http://opengeo.org
Expert service straight from the developers.
More information about the Live-demo
