[Live-demo] [OSGeo] #447: PgRouting Install Fails
OSGeo trac_osgeo at osgeo.org
Sun Sep 20 13:10:25 EDT 2009
Reporter:  darkblueb                   |       Owner:  live-demo at lists.osgeo.org
    Type:  defect                      |      Status:  new
Priority:  critical                    |   Component:  LiveDVD
Keywords:  pgrouting postgis postgres  |
 svn rev 2185
 INSERT 0 1
 ERROR:  function dijkstra_sp_delta(unknown, integer, integer, numeric)
 does not exist
 LINE 1: SELECT gid, AsText(the_geom) AS the_geom FROM dijkstra_sp_de...
 HINT:  No function matches the given name and argument types. You might
 need to add explicit type casts.
 ERROR:  function astar_sp_delta(unknown, integer, integer, numeric) does
 not exist
 LINE 1: SELECT gid, AsText(the_geom) AS the_geom FROM astar_sp_delta...
 ERROR:  function shootingstar_sp(unknown, integer, integer, numeric,
 unknown, boolean, boolean) does not exist
 LINE 1: SELECT gid, AsText(the_geom) AS the_geom FROM shootingstar_s...
Ticket URL: <http://trac.osgeo.org/osgeo/ticket/447>
OSGeo <http://www.osgeo.org/>
OSGeo committee and general foundation issue tracker.
More information about the Live-demo mailing list
