#438: Postgres 8.3 install script
  Reporter:  darkblueb  |       Owner:  live-demo at lists.osgeo.org
      Type:  defect     |      Status:  new
  Priority:  blocker    |   Component:  LiveDVD
Resolution:             |    Keywords:
Comment (by hamish):
 some updates in SVN to concern yourselves with if you are concerned about
 PostGIS:
 PostGIS 1.4 tarball download & compile has (optionally) been added to
 install_postgres.sh.  Currently this is switched off.
 A few lines in install_postgres.sh were changed outside of the optional
 bit so please (re)test, including load_postgis.sh.
 It has been deactivated until we can solidly determine if it plays nicely
 with the system & all other packages, and if it passes that a decision on
 if it should be included at all.
 TODO:
  - check if the current scripts still work;
  - check that your packages can still access their data (now and with it
 enabled);
  - check that the PostGIS 1.4 install doesn't clobber any of the 1.3
 packaged install
    * (at least the shp2pgsql binaries need to be renamed?)
  - decide if we will ship PostGIS 1.4 or not
 comments? test results?
 My personal feeling is to play it conservative and stick with the
 older packaged version at this point, but then I'm not a PostGIS person so
 I'm only cognizant of the risks and not the benefits.
 Hamish
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/438#comment:7>
OSGeo <http://www.osgeo.org/>
OSGeo committee and general foundation issue tracker.
