[Live-demo] Re: [OSGeo] #453: R script compiles from source,
debs available
Massimo Di Stefano
massimodisasha at yahoo.it
Tue Sep 22 16:05:07 EDT 2009
Il giorno 22/set/09, alle ore 20:02, Alex Mandel ha scritto:
> I already tweaked to code last night for most of these packages. I
> didn't manage to find the repo key, I'll go grab those now.
> The source method works fine I was just looking to save a little
> time on
> the build at some point.
> Is backports necessary, that's broken machines for me in the past.
no backports is not necessary.
just adding the ubuntu R repository is good, so we can switch from
R-2.8 to R 2.9.2
> Alex
> Massimo Di Stefano wrote:
>> from the page :
>> http://lib.stat.cmu.edu/R/CRAN/bin/linux/ubuntu/
>> i've notice the number of packages is limited to :
>> r-cran-boot
>> r-cran-cluster
>> r-cran-codetools
>> r-cran-foreign
>> r-cran-kernsmooth
>> r-cran-lattice
>> r-cran-matrix
>> r-cran-mgcv
>> r-cran-nlme
>> r-cran-rpart
>> r-cran-survival
>> r-cran-vr
>> r-cran-rodbc
>> maybe i'm wrong, not sure,
>> but if we delete this from the installRpackages script,
>> can we create confusion, mixing binaries and source compiled
>> packages ?
>> however, if the source build is a problem,
>> why don't build the packages just one time
>> then create a .tar.gz for the libraries
>> and upload it on the svn.
>> So each time the gisvm script well runs it has to download the
>> prebuild
>> packages instead to re-compile it
>> (this procedure can works only if we don't run apt-get update /
>> upgrade
>> on the ubuntu distro. )
>> make sense for you ?
>> Thanks,
>> Massimo.
>> P.S:
>> on a fresh ubuntu9.04 machine i activated backports run update/
>> upgrade
>> and added: :
>> deb http://<http://cran.ms.unimelb.edu.au/>/bin/linux/ubuntu jaunty/
>> gpg --keyserver subkeys.pgp.net --recv-key E2A11821
>> gpg -a --export E2A11821 | sudo apt-key add -
>> sudo apt-get update
>> sudo apt-get install r-base r-base-dev
>> can i try to build the pacjkages and create the :
>> /usr/lib/R/site-library.tar.gz?
>> or maybe is better to do this process on the gisVM machine that will
>> create the iso ?
>> Il giorno 22/set/09, alle ore 09:36, OSGeo ha scritto:
>>> #453: R script compiles from source, debs available
>>> Reporter: wildintellect | Owner: live-demo at lists.osgeo.org
>>> Type: enhancement | Status: new
>>> Priority: minor | Component: LiveDVD
>>> Resolution: | Keywords: R, CRAN
>>> Comment (by wildintellect):
>>> Attached file was run on 8.04 more packages may be present in
>>> Jaunty but
>>> it's a good start. Who wants to go through and create an apt-get and
>>> remove them from the installRpackages.r once done.
>>> Ticket URL: <http://trac.osgeo.org/osgeo/ticket/453#comment:1>
>>> OSGeo <http://www.osgeo.org/>
>>> OSGeo committee and general foundation issue
>>> tracker._______________________________________________
>>> Live-demo mailing list
>>> Live-demo at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/live-demo
More information about the Live-demo
