[Live-demo] Application install order
Cameron Shorter
cameron.shorter at lisasoft.com
Wed Sep 23 07:48:09 EDT 2009
The logic for the current order is based on:
setup.sh goes first
build_iso.sh and setdown.sh go last
the scripts which require prompts (like java) go up the top as you suggest
scripts which do fancy build compiles and which might break dependancies
go at the end, so they don't effect clean .deb build scripts. (Some of
Hamish's fancy scripts fit in here)
Alex Mandel wrote:
> Hamish wrote:
>> Alex wrote:
>>> I'm not sure what particular order the installs are run in
>> see bin/main.sh
>> when would a self-compile end in an interactive prompt?
>> Hamish
> I was asking if the order in main.sh was for a reason or mostly random.
> That's a good question, I'm not sure what I was thinking of actually.
> Alex
> Live-demo mailing list
> Live-demo at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/live-demo
Cameron Shorter
Geospatial Systems Architect
Tel: +61 (0)2 8570 5050
Mob: +61 (0)419 142 254
Think Globally, Fix Locally
Geospatial Solutions enhanced with Open Standards and Open Source
http://www.lisasoft.com
More information about the Live-demo
