[Live-demo] load_postgis.sh and the Medford dataset
Hamish
hamish_b at yahoo.com
Sat Sep 26 10:56:40 EDT 2009
Mark Leslie has put the old version of the Medford, OR PostGIS dataset
back online, and I've updated the load_postgis.sh script for it, but
neither of us have been able to test it and it is presently commented out
at the end of install_postgres.sh.
Mark wrote:
> Someone told me they'd cut the owner references and
> created a new dataset, so I allowed it to be deleted from
> the server. It has been returned, with the owner references
> removed.
> The load_postgis.sh script wasn't put in because I couldn't
> test it in a VM.
> I was hoping someone that had time to test would add it once
> it passed. I still don't have anything to test it in,
> so I'm in the same position as before. If there is
> confidence in the script, please add it to the build.
I'm in a similar position. I don't know if someone here tests it &
reports success if it will be in time for Alex's build, but it would
be good to know as then folks can run the script manually off the
DVD/VM if they want it.
It would be nice to have a little more test data on-disc though.
regards & hats off to all,
Hamish
More information about the Live-demo
