[Live-demo] ISO go/no go
Judit Mays mays at lat-lon.de
Tue Sep 29 06:16:14 EDT 2009
Jody Garnett schrieb:
> Evening; I going through with an actual burned copy of the ISO; trying
> to do a final check before things were sent to the printers.
> Deegree
> - fire fox offline trick did not work; resulting in a "firefox cannot
> establish a connection to the server at localhost:8081" (after going
> through the usual fire fox offline issue)
Hello Jody,
I am a bit surprised (and worried) about your findings. I just rechecked
with ISO-2.0 and without LAN connection.
Tomcat loads deegree, and I won't see the WMS contents unless I say that
I do *not* want to work offline. Working online even if you don't have a
wire or wireless access to the net seems to do the trick. At least it
worked here on my machine. Same thing for a colleague. on a different
machine. Could you may be try this and report back?
I can't say if it is any different with the ISO-2.0.1 version, because I
didn't download it.
Kind regards,
Judit
Desc: OpenPGP digital signature
Url : http://lists.osgeo.org/pipermail/live-demo/attachments/20090929/14d54e61/signature.bin
More information about the Live-demo mailing list
