[Live-demo] Re: [OSGeo] #467: remove bulky orphaned packages
OSGeo trac_osgeo at osgeo.org
Wed Sep 30 21:56:19 EDT 2009
  Reporter:  hamish  |       Owner:  live-demo at lists.osgeo.org
      Type:  task    |      Status:  new
  Priority:  major   |   Component:  LiveDVD
Resolution:          |    Keywords:  apt
Comment (by hamish):
 those listed packages are all installed on the disc. (well, I just checked
 for the openoffice ones and they are at least)
 check /usr/local/share/livedvd-docs/package_manifest.txt for a list of
 installed packages. (we should probably move that to $LOG_DIR ==
 /var/log/arramagong/ from $DOC_DIR)
  * in hindsight xubuntu-artwork from the above list should probably stay.
 what follows is what 'apt-get autoremove' wants to get rid of from
 2.0.0-final. anything worth keeping on the list?
 The following packages will be REMOVED:
   autotools-dev dctrl-tools debootstrap diffstat dput gettext html2text
   intltool-debian libauthen-sasl-perl libdevel-symdump-perl libdirectfb-
 dev
   libdirectfb-extra libexpat1-dev libfreetype6-dev libfribidi-dev
   libgcrypt11-dev libgeos-dev libgif-dev libgnutls-dev libgpg-error-dev
   libhdf4g-dev libhdf5-serial-dev libice-dev libicu-dev libio-pty-perl
   libio-stringy-perl libipc-run-perl libjasper-dev libldap2-dev libltdl7-
 dev
   libmail-sendmail-perl libmysqlclient15-dev libnetcdf-dev libodbcinstq1c2
   libparse-debcontrol-perl libpixman-1-dev libpod-coverage-perl
   libpthread-stubs0 libpthread-stubs0-dev libsm-dev libsqlite3-dev
   libsys-hostname-long-perl libsysfs-dev libtasn1-3-dev libterm-size-perl
   libtest-pod-perl libtiff4-dev libtiffxx0c2 libtool libx11-dev libxau-dev
   libxcb-render-util0-dev libxcb-render0-dev libxcb1-dev libxcomposite-dev
   libxcursor-dev libxdamage-dev libxdmcp-dev libxerces-c2-dev libxext-dev
   libxfixes-dev libxi-dev libxinerama-dev libxrandr-dev libxrender-dev
   libxss-dev mesa-common-dev netcdf-doc po-debconf python-all
 python2.5-dev
   unixodbc-dev unp x11proto-composite-dev x11proto-core-dev
   x11proto-damage-dev x11proto-fixes-dev x11proto-input-dev x11proto-kb-
 dev
   x11proto-randr-dev x11proto-render-dev x11proto-scrnsaver-dev
   x11proto-xext-dev x11proto-xinerama-dev xtrans-dev
 0 upgraded, 0 newly installed, 85 to remove and 0 not upgraded.
 After this operation, 116MB disk space will be freed.
 Hamish
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/467#comment:1>
OSGeo <http://www.osgeo.org/>
OSGeo committee and general foundation issue tracker.
More information about the Live-demo mailing list
