[Live-demo] 2.0.3 testing
Alex Mandel tech_dev at wildintellect.com
Wed Sep 30 23:30:42 EDT 2009
Jody Garnett wrote:
> Quick:
> - Number one advice - turn off networking before trying out the web
> applications.
> - This is very cool - I am going to use it to run my "friendly
> introduction" tutorial :-)
> Running log of test activities - I will test as much as I can before it
> goes out the door.
> udig starts up
> - data directory short cut works
> geoserver start does not work smoothly; firefox is opened before server
> is available; turning
> -- workaround - turn off networking & close firefox and click on the
> Admin GeoServer link
> - geoserver wms works
> -- png8 not transparent background for tasmania dataset; changing to png
> as workaround
> - geoserver wfs works
> - geoserver wfs-t works
> - stop geoserver worked
> deegree starts up
> - same problem as geoserver; firefox is there before the server can respond
> - deegree wms works
> -- layer metadata not correct (all the Utah datasets default to world
> extend making it hard to find them when opening an empty map - ie zoom
> to layer does not work if layer bounds not provided in capabilities
> document)
> -- getting some very fun visual gltiches due to deegree watermarking -
> ie when ortho image shown the watermark will appear once for the bounds
> of the other layers; and once for the smaller size of the orth images
> - deegree wfs capabilities document produced; udig is unable to handle
> the actual GML produced
> -- wfs layers do not provide title (resulting in only "Spring in Utah"
> being visible; rendering with 1.1.0 failed with "unknown respond result
> for GetFeature - unrecognized server error WFS_1_1_0_DataStore.java 334
> -- a bit better with 1.0.0 - basically this stuff fails when parsing the
> describe feature type response NPE in WFS_1_0_DataStore 306
> - stop deegree worked
> pgAdmin
> - crashed when I trying to view contents of Sydney database; asked me to
> report problem etc...
> - restarted ran "SELECT * FROM sydney" without problem
> - uDig connected fine and was able to run through the roads without
> problem, and display results in table view; was unable to figure out
> correct bounds for data but that is probably udig's problem
> mapsever
> - demo Itasca works
> - wms capabilities document not provided as a link anywhere I could find
> - gmap demo very pretty
> -- click to enable java mode does not work
> qgis
> - works displays countries and clouds.jpg; symbolic link in home
> directory helped here
> open jump
> kosmo
> I am out of time and cannot test any more prior to this going out. If
> anyone is available Monday we are going to try and round up volunteers
> to place the dvd into the conference bags etc...
> Jody
I take it that means we should post the 2.0.3 image to the download
server now?
Thanks,
Alex
More information about the Live-demo mailing list
