[Live-demo] Zoo Project Overview docs review
Cameron Shorter
cameron.shorter at gmail.com
Sun Aug 1 19:19:15 EDT 2010
Gerald,
Thanks for your Overview docs below, they are good.
I've tightened up the words in the introduction a bit (less words means
it is more likely to get read).
I still have a couple of comments:
* Most of our readers won't know what GEOS, OGR, WPS means, so you need
to explain these terms.
So in core features I'd include something like: "access to hundreds of
spatial algorithms like, ... and ... as provided by OGR"
We need the 2nd paragraph to explain what WPS is and what value it has
to an end user. 52N and the standards/wps_overview.rst are not much
better - more in next email.
ZOO Project¶ <cid:part1.04010808.07050609 at gmail.com>
WPS Server¶ <cid:part2.08020700.00040107 at gmail.com>
ZOO Project provides a developer friendly Web Processing Service (WPS)
framework for creating and chaining Web Processing Services. It supports
many programming languages and comes with two demo applications using
simple spatialtools Services Providers (a C shared library and a Python
module) based on the GEOS and OGR Libraries.
ZOO is made of three parts:
/ZOO Kernel/ : A powerful server-side C Kernel which makes it possible
to manage and chain Web services coded in different programming languages.
/ZOO Services/ : A growing suite of example Web services based on
various Open Source libraries.
/ZOO API/ : A server-side JavaScript API able to call and chain the ZOO
Services, which makes the development and chaining processes easier.
ZOO is based on a 'WPS Service Kernel' which constitutes the ZOO's core
system (aka ZOO Kernel). The latter is able to load dynamic libraries
and to handle them as on-demand Web services. The ZOO Kernel is written
in C language, but supports several common programming languages in
order to connect to numerous libraries and above all to simplify the Web
service end-developer's job.
A ZOO service is a link composed of a metadata file (.zcfg) and the code
for the corresponding implementation. The metadata file describes all
the available functions which can be called using a WPS Exec Request, as
well as the desired input/output. Services contain the algorithms and
functions, and can now be implemented in C/C++, Fortran, Java, Python,
PHP and JavaScript.
Core Features¶ <cid:part3.01060604.04010201 at gmail.com>
* Multi language WPS server
* Simple Web Service creation and depoyment procedure
* Simple WPS chaining with ZOO API
Implemented Standards¶ <cid:part4.06080904.02040408 at gmail.com>
* OGC WPS 1.0.0
Demo¶ <cid:part5.03090700.03030505 at gmail.com>
* Demo using simple C Services Provider based GEOS and OGR libraries
<http://localhost/zoo-demo/spatialtools.html>
* Demo using simple Python Services Provider based GEOS and OGR
libraries <http://localhost/zoo-demo/spatialtools-py.html>
* Simple html form to process your request to the ZOO Kernel
Details¶ <cid:part6.07080703.09090601 at gmail.com>
*Website:* http://zoo-project.org
*Licence:* MIT x/11
*Software Version:* 1.0
*Supported Platforms:* Windows, Linux, Mac
*Programing language support:* C, Python, Java, PHP, Fortran, Javascript
*Support:* http://zoo-project.org/trac
Cameron Shorter
Geospatial Director
Tel: +61 (0)2 8570 5050
Mob: +61 (0)419 142 254
Think Globally, Fix Locally
Geospatial Solutions enhanced with Open Standards and Open Source
http://www.lisasoft.com
Skipped content of type multipart/related
More information about the Live-demo
