[Live-demo] Re: [OSGeo] #614: OpenJUMP fails to launch
OSGeo trac_osgeo at osgeo.org
Mon Aug 2 06:46:51 EDT 2010
 Reporter:  darkblueb  |       Owner:  live-demo@…
     Type:  defect     |      Status:  new
 Priority:  critical   |   Milestone:
Component:  LiveDVD    |    Keywords:  4b5
Comment(by jsanz):
 Replying to [comment:3 hamish]:
 > Other Java projects (notably gvSIG) use JAI as well, do they have the
 same problem?
 Probably yes,
 gvSIG directly calls the java binary of {{{/usr/lib/jvm/java-6-sun/bin}}}
 on its starting script.
 As gvSIG is installed using a debian package, the sun JVM is marked as a
 dependency so if you remove {{{sun-java6-jre}}} from the disk the gvSIG
 package should be marked to be removed as well.
 gvSIG dev team has plans to support OpenJDK (and probably get rid of JAI)
 but it won't be ready until 2.0 release, I'm afraid.
 Best.
Ticket URL: <http://trac.osgeo.org/osgeo/ticket/614#comment:6>
OSGeo <http://www.osgeo.org/>
OSGeo committee and general foundation issue tracker.
More information about the Live-demo mailing list
