[Live-demo] Fwd: [OSGeo-Discuss] 1 week to test the OSGeo-Live DVD before we burn it
Massimo Di Stefano massimodisasha at gmail.com
Fri Aug 6 12:21:34 EDT 2010
Hi added a new script inside the bin directory :   install_ossim2.sh
it install a locally build version for ossim (last svn checkout) and fix a bug in imagelinker application (using qt3 instead of qt4)
tell me if i can replace the script in the main.sh so we can see if it's all ok
(i tested it locally and it should work)
Hamish :-) i'm sure the script will benefit from your eyes :-)
p.s.
in the tarbal is also included a "full" GPSTK [1] installation.
it is needed by OSSIM as dependencie,
i can cut it including only libs and headers (save 70 mb) but i prefer to leave it untouched.
GPSTK is a great piece of sw, having it on the live is cool, if you agree i can write documentation for it too
[1] http://www.gpstk.org/bin/view/Documentation/WebHome
> Il giorno 06/ago/2010, alle ore 00.25, Cameron Shorter ha scritto:
>> Massimo,
>> If your fix is not expected to effect any other application, then please apply your fix.
>> If another application might be effected, could you please discuss this on the list first, before we make a decision either way.
>> On 06/08/10 07:42, Massimo Di Stefano wrote:
>>> hi Cameron,
>>> seems i find a solution,
>>> i build the software locally on a fresh xubuntu and i stored all the build in a directory (150 mb)
>>> i tried it on the live-gis VM and it works as aspected (it only need the LD_LIBRARY_PATH to be setted)
>>> tell me i can i add a replacement of install_ossim.sh to try thi procedure unless a new debian packages will ready.
>>> Il giorno 05/ago/2010, alle ore 23.01, Cameron Shorter ha scritto:
>>>> Thanks for trying to track down this issue Massimo asap.
>>>> I understand that Alex will be cutting a final release candidate, which will hopefully become the final release this Monday 9 Aug. If you fix the issue, we can verify it works, and hasn't effected any other packages on that release.
>>>> On 05/08/10 18:38, Massimo Di Stefano wrote:
>>>>> Hi All,
>>>>> from the osgeo live list :
>>>>> Inizio messaggio inoltrato:
>>>>>>> The OSGeo-Live DVD is looking great, with 43 pre-configured GeoSpatial
>>>>>>> Open Source packages and marketing documentation.
>>>>>>> It will be sent to the printers next week, Monday 9 August, and we are
>>>>>>> calling on all projects to test their applications and documentation
>>>>>>> and verify everything is working fine.
>>>>>>> Could everyone with an interest please:
>>>>>>> download an ISO or Virtual Machine from here:
>>>>>>> http://download.osgeo.org/livedvd/4.0-rc6/
>>>>>>> run (and update) test steps for your project. Test steps might be "Run
>>>>>>> steps in QuickStart". Record results here:
>>>>>>> http://wiki.osgeo.org/wiki/Live_GIS_Disc_Testing
>>>>>>> review documentation:
>>>>>>> http://download.osgeo.org/livedvd/4.0-rc6/osgeolive-docs/index.html
>>>>>>> if inspired - write a quickstart, or add screen shots to an existing quickstart.
>>>>>>> fix anything that is broken
>>>>> Ossim is present on the live-dvd thanks to the ubuntu packages prepared by Pirimin K.
>>>>> testing it i can see Imagelinker is built using ossim_qt4 instead of qt3, this give us a non-full working imagelinker :-(
>>>>> right now i'm preparing a fresh VM on which i'll try to rebuild imagelinker and ossimplanet from svn,
>>>>> unlucky i have no experience building .deb ...
>>>>> maybe using a cmake build "out of source" i can try to build a "static version" for all the ossim suite.
>>>>> here my question :
>>>>> using cmake i'm able to choose wich part of ossim i should build
>>>>> but i can't find an entry to choose between ossim_qt or ossim_qt4
>>>>> i can see only ossim_qt4 [ON/OFF]
>>>>> Pirimin, have you time/resource to build a new packages .deb ?
>>>>> Please, i'm avaiable at any time to try to generate a new .deb
>>>>> thanks to anyone who has experience on this side.
>>>>> Ciao,
>>>>> Massimo.
>>>>> _______________________________________________
>>>>> Live-demo mailing list
>>>>> Live-demo at lists.osgeo.org
>>>>> http://lists.osgeo.org/mailman/listinfo/live-demo
>>>> Cameron Shorter
>>>> Geospatial Director
>>>> Tel: +61 (0)2 8570 5050
>>>> Mob: +61 (0)419 142 254
>>>> Think Globally, Fix Locally
>>>> Geospatial Solutions enhanced with Open Standards and Open Source
>>>> http://www.lisasoft.com
>> Cameron Shorter
>> Geospatial Director
URL: http://lists.osgeo.org/pipermail/live-demo/attachments/20100806/c55897a6/attachment.html
More information about the Live-demo mailing list
