[Live-demo] Fwd: [OSGeo-Discuss] 1 week to test the OSGeo-Live
DVD before we burn it
Massimo Di Stefano
massimodisasha at gmail.com
Sat Aug 7 11:19:19 EDT 2010
Apologize me i gorghet to send the message to the list i'm fwd it.
update, i have ulteriorly reduced the size
(i deleted the sonamed libs, there are a lot of duplicates,
i suppose we don't need them on the live)
the full size for "usr/local/ossim" is now around 65 mb
thanks to help me to tune the script.
Massimo.
Il giorno 07/ago/2010, alle ore 16.40, Massimo Di Stefano ha scritto:
> Hamish thanks for th help :-)
> Il giorno 07/ago/2010, alle ore 07.20, Hamish ha scritto:
>>> Massimo wrote:
>>> Hi added a new script inside the bin directory :
>>> install_ossim2.sh
>>> it install a locally build version for ossim (last svn
>>> checkout) and fix a bug in imagelinker application
>>> (using qt3 instead of qt4)
>> some edits were needed; please retest (too big a DL for me)
> i tried to remove all the gpst files that are not needed by ossim
> the uncompressed "ossim" directory size changes from 440 mb to 240 mb
> (it save 200 mb)
> .. but we lost gpstk, we can add it later or in a different release
> (maybe a release without mac and win sw ?)
>> * use /tmp/build_ossim
> ok
>> * gdal 1.7.0 req's ubuntugis
> i thinked ubuntugis well be added as default, i'm wrong ?
> the lines to enable ubuntugis are commented out,
> need i to uncomment them and add an "if statment" to check if
> /etc/apt/sources.list.d/ubuntugis.list
> already exists and if it is not present, add it ?
>> * sudo not needed, already running as root
> ok
>> * use --progress with wget for flat text output
>> * do not use wget -c with unversioned filenames (corrupts)
>> use -N instead to go by timestamp instead of filesize,
>> although with -O it's a no-op
> i changed it to : wget -N --progress=dot:mega
> is it ok ?
>> * avoid verbose mode
>> * linewrap ..
> apologize me, :-) i haven't undstand
> (my poor english and lack of IT background)
> what about "verbose" ?
> can i add in the script a line like :
> set +o verbose
> what's "linewarp" ?
> i attacjhed the modified script :
> <install_ossim2.sh>
>> cheers,
>> Hamish
>> ps- zoo now enabled in main.sh
> cool, looking forward to see it in action! i'm inttersted in wps
> p.s.
> i contacted the guys will have a pywps workshop at foss4g 2010
> they are busy but intersted to add pywps in the live
> i'm still whaiting for the needed scripts.
More information about the Live-demo
