[Live-demo] Provide .fix files for all Shapefiles
Stefan A. Tzeggai tzeggai at wikisquare.de
Wed Aug 11 05:24:35 EDT 2010
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
Hi
Jody wrote:
JG> That is great you got a command line tool going (indeed that was very
JG> quick). Updating the script (perhaps the atlas styler script) to
JG> create the .fix files is the best option today.
Accoring to bin/main.sh the bin/install_gisdata.sh is executed after
bin/install_atlasstyler.sh, so the following patch is open for comments.
Index: install_gisdata.sh
- --- install_gisdata.sh	(revision 4603)
+++ install_gisdata.sh	(working copy)
@@ -36,6 +36,13 @@
    exit 1
 fi
+# check required tools are installed
+if [ ! -x "`which atlasstyler`" ] ; then
+   echo "ERROR: atlasstyler is required as a tool to create .fix files
for all shapefiles, please install it with bin/install_atlasstyler.sh
and try again"
+   exit 1
+fi
 # create tmp folders
 mkdir "$TMP"
 cd "$TMP"
@@ -84,6 +91,13 @@
   unzip "$file" -d "$DATA_FOLDER/natural_earth"
 done
+# Add Geotools .fix files to all Shapefiles. Normally Geotools
application would create these
+# files when opeing the Shapefile, but since the data-dir is read-only,
we do it here.
+# This REQUIRES that install_atlasstyler.sh has been executed before
(which is checked above)
+find "$DATA_FOLDER/natural_earth" -iname "*.shp" -exec atlasstyler
"addFix={}" \;
 chmod a+r "$DATA_FOLDER/natural_earth"     ## read the data dir
 chmod 444  $DATA_FOLDER/natural_earth/*    ##  and all files in it
 chmod -R +X "$DATA_FOLDER/natural_earth"   ## but keep x on directories
Am 11.08.2010 01:47, schrieb Jody Garnett:
> Small correction: It is especially annoying that this .fix index is
> not even a spatial index - it is used to preserve row order when
> editing. As a result the index files are very small.
> Can I also ask if there is a "qix" spatial index?
> (we will be getting that patch into GeoTools so the solution to
> generate a fix file should be viewed as temporary and only needed to
> get our live dvd release deadlines).
> Jody
> On Wed, Aug 11, 2010 at 2:38 AM, Stefan A. Tzeggai
> <tzeggai at wikisquare.de> wrote:
> Hi
> 1. good news: I debugged AtlasStyler and Geopublisher today a OSGeoLive
> system and fixed all the problems reported.
> AS and GP now have no more problems when opening a Shapefile without a
> .fix spatial index from a read-only drive - it doesn't try to create the
> index anymore.
> 2. The problem with read-only and .fix lies in Geotools, so it affects
> uDig also.
> 3. I created a patch for Geotools
> (http://jira.codehaus.org/browse/GEOT-3245) but it is not yet reviewed.
> Options are:
> A: Get the patch into Geotools and make a new release of Geotools and uDig
> Advantage: No big changes on the OSGeo side.
> Disadvantage: Lots of work for Jody. uDig, Geopublisher, AtlasStyler and
> will not profit from a spatial index when working with the demo
> shapefile data.
> B: Create .fix indexes during build after the Shapefiles are unzipped
> and while the drive is still read-write.
> .fix are Geotools-specific, so ogr doesn't create these files. We need a
> command line tool to add .fix indexes if we want it to be done in
> 'bin/loadgisdata.sh'. Such a tool doesn't exists yet... So i added a
> command line option to AtlasStyler 1.5 that does exactly that.
> So for option B, we have to do only one thing: Add a line to
> 'bin/install_atlasStyler' that will add a spatial index to all
> shapefiles in the $DATA_FOLDER:
>>>> find $DATA_FOLDER -iname "*.shp" -exec atlasstyler "addFix={}" \;
> This REQUIRES that 'bin/loadgisdata.sh' is run before
> install_AtlasStyler.sh is run.
> Actually install_Gisdata is setting the data read-only already. So in
> the install_AtlasStyler.sh i will have to change the permissions twice..
> something not so nice.
> Advantage: No quick re-releasing of Geotools and uDig just for one patch
> two days after the last release.
> Disadvantage: Some unorthodox modifications on the install scripts.
> A or B ? Waiting for feedback.
> Greetings,
> Steve
> Am 10.08.2010 13:33, schrieb Cameron Shorter:
>>>> The naturalearth data shapefiles are loaded by bin/loadgisdata.sh
>>>> It is loaded from the naturalearth website directly.
>>>> I'm open to you adding .fix files if you think it is easy enough to
>>>> achieve.
>>>> On 10/08/10 21:10, Stefan A. Tzeggai wrote:
>>>> Hi
>>>> I have installed the rc5 to my HDD and started investigating the
>>>> problems reported for AtlasStyler and Geopublisher. This is what happens:
>>>> The natural earth shapes don't have .fix spatial indexes. AtlasStyler
>>>> tries to create them on-the-fly and gets a permission exception.
>>>> I will write a fix, so that that will not be a problem anymore, but
>>>> maybe we should anyways add .fix files to all Shapefiles on the DVD.
>>>> .fix files are supported by Geotools, so uDig, Geoserver,
>>>> Geopublisher and AtlasStyler (and probably more) would profit
>>>> performance-wise.
>>>> The data dir is not in the svn.. Tell me where it is, and i can provide
>>>> .fix files for all shapefiles.
>>>> Greetings,
>>>> Steve
>>>> -- wiki² - Softwareentwicklung
>>>> Stefan A. Tzeggai, geb. Krüger
>>>> Straßburger Weg 26
>>>> 53113 Bonn
>>>> email   tzeggai at wikisquare.de
>>>> phone   0228 24 000 528
>>>> mobile  0176 40 38 9559
>>>> webpage wikisquare.de
>>>> twitter http://twitter.com/geopublishing
>>>> skype   alfonx
>>>> reclaim your net - http://tor.eff.org
>>>> enforce privacy - http://www.pgpi.org
>>>> pgp key id: 51B576FD - http://pgp.mit.edu
>>>> Please note that according to the German law on data retention,
>>>> information on every electronic information exchange with me is
>>>> retained for a period of six months.
> Live-demo mailing list
> Live-demo at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/live-demo
> http://wiki.osgeo.org/wiki/Live_GIS_Disc
Straßburger Weg 26
53113 Bonn
skype   alfonx
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.10 (GNU/Linux)
Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org/
iEYEARECAAYFAkxibFMACgkQdFDQR1G1dv2U/gCgl/P8IwiQVa/oOcDljFpLqy4e
stYAnieZB74X1knG1nviCGf4UHapayZm
=tsma
-----END PGP SIGNATURE-----
More information about the Live-demo mailing list
