[Live-demo] Provide .fix files for all Shapefiles
Cameron Shorter cameron.shorter at gmail.com
Wed Aug 11 07:18:42 EDT 2010
Please go ahead and apply this patch.
Please also run the install_gisdata.sh script, and confirm that it works
as expected, and that the other applications like UDig work.
On 11/08/10 19:24, Stefan A. Tzeggai wrote:
> -----BEGIN PGP SIGNED MESSAGE-----
> Hash: SHA1
> Hi
> Jody wrote:
> JG>  That is great you got a command line tool going (indeed that was very
> JG>  quick). Updating the script (perhaps the atlas styler script) to
> JG>  create the .fix files is the best option today.
> Accoring to bin/main.sh the bin/install_gisdata.sh is executed after
> bin/install_atlasstyler.sh, so the following patch is open for comments.
> Index: install_gisdata.sh
> - --- install_gisdata.sh	(revision 4603)
> +++ install_gisdata.sh	(working copy)
> @@ -36,6 +36,13 @@
>      exit 1
>   fi
> +# check required tools are installed
> +if [ ! -x "`which atlasstyler`" ] ; then
> +   echo "ERROR: atlasstyler is required as a tool to create .fix files
> for all shapefiles, please install it with bin/install_atlasstyler.sh
> and try again"
> +   exit 1
> +fi
>   # create tmp folders
>   mkdir "$TMP"
>   cd "$TMP"
> @@ -84,6 +91,13 @@
>     unzip "$file" -d "$DATA_FOLDER/natural_earth"
>   done
> +# Add Geotools .fix files to all Shapefiles. Normally Geotools
> application would create these
> +# files when opeing the Shapefile, but since the data-dir is read-only,
> we do it here.
> +# This REQUIRES that install_atlasstyler.sh has been executed before
> (which is checked above)
> +find "$DATA_FOLDER/natural_earth" -iname "*.shp" -exec atlasstyler
> "addFix={}" \;
>   chmod a+r "$DATA_FOLDER/natural_earth"     ## read the data dir
>   chmod 444  $DATA_FOLDER/natural_earth/*    ##  and all files in it
>   chmod -R +X "$DATA_FOLDER/natural_earth"   ## but keep x on directories
> Am 11.08.2010 01:47, schrieb Jody Garnett:
>> Small correction: It is especially annoying that this .fix index is
>> not even a spatial index - it is used to preserve row order when
>> editing. As a result the index files are very small.
>> Can I also ask if there is a "qix" spatial index?
>> (we will be getting that patch into GeoTools so the solution to
>> generate a fix file should be viewed as temporary and only needed to
>> get our live dvd release deadlines).
>> Jody
>> On Wed, Aug 11, 2010 at 2:38 AM, Stefan A. Tzeggai
>> <tzeggai at wikisquare.de>  wrote:
>> Hi
>> 1. good news: I debugged AtlasStyler and Geopublisher today a OSGeoLive
>> system and fixed all the problems reported.
>> AS and GP now have no more problems when opening a Shapefile without a
>> .fix spatial index from a read-only drive - it doesn't try to create the
>> index anymore.
>> 2. The problem with read-only and .fix lies in Geotools, so it affects
>> uDig also.
>> 3. I created a patch for Geotools
>> (http://jira.codehaus.org/browse/GEOT-3245) but it is not yet reviewed.
>> Options are:
>> A: Get the patch into Geotools and make a new release of Geotools and uDig
>> Advantage: No big changes on the OSGeo side.
>> Disadvantage: Lots of work for Jody. uDig, Geopublisher, AtlasStyler and
>> will not profit from a spatial index when working with the demo
>> shapefile data.
>> B: Create .fix indexes during build after the Shapefiles are unzipped
>> and while the drive is still read-write.
>> .fix are Geotools-specific, so ogr doesn't create these files. We need a
>> command line tool to add .fix indexes if we want it to be done in
>> 'bin/loadgisdata.sh'. Such a tool doesn't exists yet... So i added a
>> command line option to AtlasStyler 1.5 that does exactly that.
>> So for option B, we have to do only one thing: Add a line to
>> 'bin/install_atlasStyler' that will add a spatial index to all
>> shapefiles in the $DATA_FOLDER:
>>>>> find $DATA_FOLDER -iname "*.shp" -exec atlasstyler "addFix={}" \;
>> This REQUIRES that 'bin/loadgisdata.sh' is run before
>> install_AtlasStyler.sh is run.
>> Actually install_Gisdata is setting the data read-only already. So in
>> the install_AtlasStyler.sh i will have to change the permissions twice..
>> something not so nice.
>> Advantage: No quick re-releasing of Geotools and uDig just for one patch
>> two days after the last release.
>> Disadvantage: Some unorthodox modifications on the install scripts.
>> A or B ? Waiting for feedback.
>> Greetings,
>> Steve
>> Am 10.08.2010 13:33, schrieb Cameron Shorter:
>>>>> The naturalearth data shapefiles are loaded by bin/loadgisdata.sh
>>>>> It is loaded from the naturalearth website directly.
>>>>> I'm open to you adding .fix files if you think it is easy enough to
>>>>> achieve.
>>>>> On 10/08/10 21:10, Stefan A. Tzeggai wrote:
>>>>> Hi
>>>>> I have installed the rc5 to my HDD and started investigating the
>>>>> problems reported for AtlasStyler and Geopublisher. This is what happens:
>>>>> The natural earth shapes don't have .fix spatial indexes. AtlasStyler
>>>>> tries to create them on-the-fly and gets a permission exception.
>>>>> I will write a fix, so that that will not be a problem anymore, but
>>>>> maybe we should anyways add .fix files to all Shapefiles on the DVD.
>>>>> .fix files are supported by Geotools, so uDig, Geoserver,
>>>>> Geopublisher and AtlasStyler (and probably more) would profit
>>>>> performance-wise.
>>>>> The data dir is not in the svn.. Tell me where it is, and i can provide
>>>>> .fix files for all shapefiles.
>>>>> Greetings,
>>>>> Steve
>>>>> -- wiki² - Softwareentwicklung
>>>>> Stefan A. Tzeggai, geb. Krüger
>>>>> Straßburger Weg 26
>>>>> 53113 Bonn
>>>>> email   tzeggai at wikisquare.de
>>>>> phone   0228 24 000 528
>>>>> mobile  0176 40 38 9559
>>>>> webpage wikisquare.de
>>>>> twitter http://twitter.com/geopublishing
>>>>> skype   alfonx
>>>>> reclaim your net - http://tor.eff.org
>>>>> enforce privacy - http://www.pgpi.org
>>>>> pgp key id: 51B576FD - http://pgp.mit.edu
>>>>> Please note that according to the German law on data retention,
>>>>> information on every electronic information exchange with me is
>>>>> retained for a period of six months.
>> Live-demo mailing list
>> Live-demo at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/live-demo
>> http://wiki.osgeo.org/wiki/Live_GIS_Disc
> Straßburger Weg 26
> 53113 Bonn
> skype   alfonx
> -----BEGIN PGP SIGNATURE-----
> Version: GnuPG v1.4.10 (GNU/Linux)
> Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org/
> iEYEARECAAYFAkxibFMACgkQdFDQR1G1dv2U/gCgl/P8IwiQVa/oOcDljFpLqy4e
> stYAnieZB74X1knG1nviCGf4UHapayZm
> =tsma
> -----END PGP SIGNATURE-----
Cameron Shorter
Geospatial Director
Tel: +61 (0)2 8570 5050
Mob: +61 (0)419 142 254
Think Globally, Fix Locally
Geospatial Solutions enhanced with Open Standards and Open Source
http://www.lisasoft.com
More information about the Live-demo mailing list
