[Live-demo] Re: [OSGeo-Discuss] USB testing required today if
we are to hand out OSGeo-Live on a USB at FOSS4G
Cameron Shorter
cameron.shorter at gmail.com
Sun Aug 15 16:53:49 EDT 2010
Thanks Noli and Daniel,
I've updated the wiki with some of your tips here:
http://wiki.osgeo.org/wiki/Live_GIS_Disc_Quick_Start_for_USB
It would be great if you could add a "Trouble Shooting" heading
underneath if you have extra information that you think is appropriate.
On 15/08/10 16:15, Alex Mandel wrote:
> Ah, crazy that's totally it. The usb device must be in when I go the
> BIOS settings, and a new option showed up in the Boot area to order the
> Hard Drives.
> Removable Device != USB stick
> So strange, thanks for the hint. It works fine now.
> Alex
> On 08/14/2010 11:06 PM, Daniel Kastl wrote:
>> My first bios settings for boot order failed, because I moved the "removable
>> device" up in the boot menu order, but surprisingly this wasn't my USB
>> stick.
>> The USB stick was listed under hard drives option, which showed a "+" and
>> contained a list of drives including the USB drive. I had to move it up to
>> be booted before the main HDD. Then it worked.
>> Daniel
>> 2010/8/15 Alex Mandel<tech_dev at wildintellect.com>
>>> On 08/14/2010 05:35 PM, Noli Sicad wrote:
>>>> Hi Cameron,
>>>>> Ideally we would have liked to distribute on a USB to all delegates
>>>>> however out of the 5 or so computers tested, we've had reports of at
>>>>> least 2 computers which can't boot from the USB. So we will distribute
>>>>> OSGeo-Live to all delegates on the well tested DVD version.
>>>> These laptops / desktops have faulty Windows BIOS. They need DSDT
>>>> patching to boot Linux OS and Darwin OS (Mac OS X). Using IASL, you
>>>> can decompile the BIOS i.e. dump DSDT.dsl. then patch it and compile.
>>>> Use dsdt.aml to boot usb linux os.
>>>> Top of the list for faulty BIOS is HP Pavillion laptops.
>>>> I got HP Pavillion DM3 which I have been patching inorder to triple
>>> boot.
>>>> The solution to create various version of OSGeo Live USB for these
>>> laptops.
>>>> 1. HP Pavillion
>>>> 3. Dell
>>>> 2. Asus
>>>> BTW, what are the brand of those computers which did not boot?
>>>> I could help create these OSGeo Live USB to work properly with these
>>>> laptops, if you are interested and provide the resources i.e. 4Gb /
>>>> 8Gb USBes, OSGeo ISO and dsdt.aml from those not booting laptops. I
>>>> will patch it. I can pick these things in your Melbourne office, if
>>>> you are interested.
>>>>> However, if we can get test results from enough people by first thing,
>>>>> Monday 16 August, an OSGeo-Live USB will be created and given to VIPs.
>>>> Regards, Noli
>>> I'm not sure that's 100% right. My Asus is failing to boot from usb, and
>>> I do think it's a BIOS issue but it has nothing to do with the OS. The
>>> laptop is a linux box only, it seems to just never try booting usb even
>>> though it's in the list.
>>> Also making multiple versions of the usb sticks depending on the laptop
>>> brand is unrealistic, if that's what it takes to make it work 95% of the
>>> time or better we're going to have to stick to mostly DVDs for this
>>> release.
>>> Thanks for the info, I'll have to poke into that more.
>>> Alex
>>> Live-demo mailing list
>>> Live-demo at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/live-demo
>> Discuss mailing list
>> Discuss at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/discuss
Cameron Shorter
Geospatial Director
Tel: +61 (0)2 8570 5050
Mob: +61 (0)419 142 254
Think Globally, Fix Locally
Geospatial Solutions enhanced with Open Standards and Open Source
http://www.lisasoft.com
More information about the Live-demo
