[Live-demo] hybrid dvd and usb drive ISOs possible
Cameron Shorter cameron.shorter at gmail.com
Sat Aug 21 16:19:07 EDT 2010
On 20/08/10 21:12, Hamish wrote:
> fyi, with the Debian live-helper method it is now possible to create a
> single hybrid ISO which can be either burned to a DVD or dd'ed directly
> to the USB drive*. no need to use the "Make Startup Disk" app.
>    http://lists.debian.org/debian-live/2010/07/msg00171.html
> I don't know if this means you can get away from formatting as fat32
> (highly inefficient on>gb partitions), or if that stems from a
> limitation of common BIOSes.
> [*] e.g.:  dd if=liveboot.iso of=/dev/sdc
Interesting. From reading the article, it is still looking very alpha. I
assume that we would start making use of it in our build once this
functionality is rolled into Ubuntu?
Cameron Shorter
Geospatial Director
Tel: +61 (0)2 8570 5050
Mob: +61 (0)419 142 254
Think Globally, Fix Locally
Geospatial Solutions enhanced with Open Standards and Open Source
http://www.lisasoft.com
More information about the Live-demo mailing list
