[Live-demo] Geomajas: missing '.sh'
Hamish hamish_b at yahoo.com
Tue Feb 2 03:36:57 EST 2010
Pieter De Graef wrote:
> I changed the main.sh file to fix this but found something curious.
> I opened the shell file in windows notepad, and saw readable text.
> Normally notepad uses different end of line characters, and so a shell
> script should normally be pretty unreadable. Doesn't this cause you any
> problems?
No problem. I regularly run over the repo with a Subversion propset
checking script whenever new files are being added. One thing it does
for text files is set the "svn:eol-style" tag to "native". So it even
works with notepad.exe. (ppssst- get TextPad or Notepad++)
Thus whenever you check out or check in that file to svn it gets adjusted
automatically, and you can use whatever tools or OS you like.
Hamish
More information about the Live-demo mailing list
