[Live-demo] A folder for beta software
Juan Lucas Domínguez Rubio
juan_lucas_dr at yahoo.com
Tue Feb 2 09:08:56 EST 2010
Hello,
Yes, I realized the GIS icons are scattered in various places in the apps menu (some are missing I think). That's why I proposed to concentrate on the beta packages which should be identified as such in some way.
BTW, which are the beta packages? Kosmo 2 and ugvsigmobile are described as beta in the Google doc, any others?
http://spreadsheets.google.com/ccc?key=0Al9zh8DjmU_RdGIzd0VLLTBpQVJuNVlHMlBWSDhKLXc&hl=en
Hamish: that part of the script worked fine in yesterday's build? I mean, have you seen the new 'Applications/Science/Geoscience/GRASS GIS' menu item? (I can't see it in the click2try image).
Regards,
Juan Lucas
--- On Tue, 2/2/10, Hamish <hamish_b at yahoo.com> wrote:
> From: Hamish <hamish_b at yahoo.com>
> Subject: Re: [Live-demo] A folder for beta software
> To: live-demo at lists.osgeo.org, "Cameron Shorter" <cameron.shorter at lisasoft.com>
> Date: Tuesday, February 2, 2010, 1:45 PM
> Cameron:
> > I suggest that we should set up a new category (on the
> same
> > level as Education) called "Geospatial"
> > So we would have:
> > Geospatial/gvsig
> > Geospatial/geoserver
> > Geospatial/beta/gvsig-mobile
> fyi a number of scripts already create new menu
> items/branches
> using the WM-independent "update-menus" system.
> e.g. this in install_grass.sh creates a
> Geoscience menu and puts "GRASS GIS" as an entry in it:
> # add menu item
> if [ ! -e /usr/share/menu/grass ] ; then
> cat << EOF >
> ?package(grass):needs="text"\
> section="Applications/Science/Geoscience"\
> title="GRASS GIS"\
> command="/usr/bin/grass$GVER"\
> icon="/usr/share/icons/grass-48x48.png"
> EOF
> update-menus
> fi
> I'm not really opposed to it, but I'm not entirely sure why
> we
> need a second parallel method to do the same thing.
> $ man update-menus
> DESCRIPTION
> Before the advent of
> update-menus, when the system administra-
> tors installed a
> package onto a Debian system, they would need
> to edit various window
> manager configuration files to make the
> new program
> show up on, for example, fvwm's menus. The menus
> could easily become out of
> sync with what programs were actu-
> ally available,
> with some menu items that didn't work,
> and
> other programs that
> lacked a menu
> entry. update-menus and
> Debian's menu package aim
> to solve this problem.
> update-menus
> automatically generates menus of installed pro-
> grams for window managers
> and other menu programs. It should be
> run whenever
> a menufile(5) or menu-method file is
> changed.
> update-menus will be
> run automatically when Debian
> packages
> that contain
> menu files are installed on or removed from the
> system.
> update-menus uses the
> package-supplied menu entry files
> (in
> /usr/share/menu) for
> its information about the menus (but this
> can be overruled by the
> system administrator/user; see below).
> If a menu entry
> file is executable, update-menus executes the
> menu entry file, and
> uses its stdout to generate
> the menu
> database.
> > Once you have worked out how it should be done, could
> you
> > please also update the build wiki so that others can
> follow
> > your steps.
> > http://wiki.osgeo.org/wiki/GISVM_Build
> (renamed that to http://wiki.osgeo.org/wiki/Live_GIS_Build btw)
> Hamish
> Live-demo mailing list
> Live-demo at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/live-demo
More information about the Live-demo
