[Live-demo] Adding Geomajas to the Live DVD
Pieter De Graef pieter.degraef at geosparc.com
Tue Jan 26 03:04:40 EST 2010
I've been having problems with the bleeding edge version. I've
downloaded the files, but the md5sum results are different from what I
read on the website.
When combining the files into the one 7z file (using cat), I was not
able to open the file.
So I downloaded everything again, and again with the same result...
So I'll try downloading every release I can, in the hope that I can get
one of them up and running to test the scripts.
Alex Mandel schreef:
> The torrent is the previous stable version 2.0.
> You'll want to test on the latest alpha which uses a newer version of
> ubuntu.
> Scroll part way down on the download page to "Bleeding Edge unstable
> releases Arramagong GISVM and LiveDVD - 3.0-alpha3"
> #  arramagong-3.0-alpha3.7z.0
> (1.5G) md5sum: 9913a2b205b1536e4bec1a3cf7a29d97
> # arramagong-3.0-alpha3.7z.1
> (1.5G) md5sum: 602006dc21f4e5c00e872403b2dc803c
> # arramagong-3.0-alpha3.7z.2
> The file is split in 3 parts due to a limitation on the server but it's
> easy to put them back together using the cat command (There's an example
> on the page.
> I'll try and get to testing your script later today when I work on some
> other ones.
> Thanks,
> Alex
> Pieter De Graef wrote:
>> I am busy downloading the Live DVD through torrents, but it's going a
>> bit slow. After 2 days, I'm at 8%...
>> Although today it seems to be going faster.
>> Cameron Shorter schreef:
>>> Thanks Pieter,
>>> Until we get the click2try browser based LiveDVD development image up
>>> and running, the process to test the LiveDVD is:
>>> * Download the latest virtual machine (version 3.0alpha3). See details
>>> at: http://download.osgeo.org/livedvd/
>>> If the above will take too much bandwidth, you can cheat by using an
>>> ubuntu or xubuntu 9.10 distribution you have already, and this should
>>> be sufficient to find most bugs.
>> Sorry to say, but I myself seem to be a windows user.... I was testing
>> on a ubuntu without the root password (so a few steps - such as the
>> desktop icon creation - have not been tested properly), so yes there
>> could still be problems.
>>> * Run the image as a virtual machine
>>> http://wiki.osgeo.org/wiki/Live_GIS_Disc_Quick_Start#Arramagong_Live_Virtual_Machine
>>> * log into the livedvd, user=user, pass=user, cd to the livedvd svn
>>> directory, update it, and then execute the script:
>>> cd /home/user/gisvm/bin/
>>> svn update
>>> ./build_geomajas.sh
>>>> Thanks.
>>>> I've added the script to SVN. Is there a way for me to see if it
>>>> works as it should?
>>>> I've based it upon the GeoServer install script. Hope they don't mind
>>>>>> Also, could it be that this userid is the same as the OSGeo
>>>>>> website login? Because it said, that the userid already existed.
>>>>>> Anyway, I think this is it: pieterdg See
>>>>>> https://www.osgeo.org/user/335
>>>>> right. I've now activated your svn access.
>>>>> see other scripts for examples.
>>>>> regards & welcome,
>>>>> Hamish
>>>> Pieter De Graef
>>>> GeoSparc nv.
>>>> http://www.geosparc.com/
>>>> Sponsor of: http://www.geomajas.org/
>>>> _______________________________________________
>>>> Live-demo mailing list
>>>> Live-demo at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/live-demo
Pieter De Graef
GeoSparc nv.
URL: http://lists.osgeo.org/pipermail/live-demo/attachments/20100126/37b96f35/attachment.html
More information about the Live-demo mailing list
