[Live-demo] Kosmo 2.0 scripts update
Cameron Shorter cameron.shorter at gmail.com
Mon Jul 5 17:26:51 EDT 2010
Sergio Baños Calvo wrote:
> 1) We would like to add one or two simple projects to show Kosmo
> possibilities using the data stored at the LiveDVD. Could we add those
> after the 5th July feature freeze?
Thanks Sergio, that would be great. I suggest that this should be
referenced in the QuickStart documentation that I'll be asking for.
> I've been checking some data for PostgreSQL at alpha 4 but the tables
> contained are almost empty (there are no geometry tables inside).
We have had issues with our postgis loader script.  I think Brian has
been looking into this.
We are looking to make use of a common dataset which is used by most
projects.
So far, we have installed a set of shapefiles and raster data from the
NaturalEarth dataset (as per the install_gisdata.sh script).
It sounds like we also need to load this data into postgis as well.
(Volunteers welcome)
> 2) I haven't check yet the JRE that is shipped with Udig to allow
> saving 70-80 Mb from Kosmo install. If it goes fine, I'd change the
> download to not contain it and the launcher to use the Udig JRE instead.
We install sun jre and jdk 1.6, and strongly encourage all other
projects to make use of it. As you mention, it saves a lot of space.
Cameron Shorter
Geospatial Solutions Manager
Tel: +61 (0)2 8570 5050
Mob: +61 (0)419 142 254
Think Globally, Fix Locally
Geospatial Solutions enhanced with Open Standards and Open Source
http://www.lisasoft.com
More information about the Live-demo mailing list
