[Live-demo] Re: [OSGeo] #542: Postgis & pgRouting Icon
OSGeo trac_osgeo at osgeo.org
Wed Jul 7 09:03:02 EDT 2010
 Reporter:  wildintellect  |       Owner:  live-demo@…
     Type:  task           |      Status:  new
 Priority:  normal         |   Milestone:
Component:  LiveDVD        |    Keywords:  4.0
Comment(by hamish):
 Replying to [comment:7 darkblueb]:
 > but this has to be tested...
 tested, it works AFAICT, thanks.
 but I've run into another problem: Mapnik 0.7's PostGIS plugin fails.
 GpsDrive gives this error message:
 Cannot init mapnik. Mapnik support DISABLED: Could not create
  datasource. No plugin found for type 'postgis' (encountered
  during parsing of layer 'leisure')
 yet the `/usr/lib/mapnik/0.7/input/postgis.input` file is there..
 maybe mapnik needs a recompile for postgis 1.5 as well? if so we've either
 got to put in another request to UbuntuGIS or drop back to the standard
 postgis 1.4.
 I suggest someone with the latest VM may want to try to see if the 'Start
 Mapnik & TileLite' button still works.
 further tests here:
  http://live.osgeo.org/doc/mapnik_description.html
 (and of course test pgRouting too)
 Dane, the osm2pgsql svn checkout ended up with a 122mb svn-trunk/ dir
 (ouch), so I just made a .deb of the latest svn and threw it up on our
 download server. the .deb is 60kb. :) hopefully there are no dependency
 problems from this in the next build..
 Hamish
Ticket URL: <http://trac.osgeo.org/osgeo/ticket/542#comment:8>
OSGeo <http://www.osgeo.org/>
OSGeo committee and general foundation issue tracker.
More information about the Live-demo mailing list
