[Live-demo] Still add some demo data?
    Cameron Shorter
    cameron.shorter at gmail.com
    Tue Jul 27 16:05:45 EDT 2010
Johan,
Sounds reasonable. Yes, lets revisit the question of datasets after this
release.
On 27/07/10 21:56, Johan Van de Wauw wrote:
> In that case maybe some raster data should be added to the mix: the
> only raster which is available now is an already rendered image, which
> is not very useful if you want to show some raster processing
> capabilities.
> Perhaps too late for this edition, but later the global elevation
> could be added. This and some other global raster datasets can be
> downloaded from this site (we should check license etc.. though)
> http://www.worldclim.org/current
> Anyway for the time being I've kept my example using our own dataset.
> On Tue, Jul 27, 2010 at 1:20 PM, Cameron Shorter
> <cameron.shorter at gmail.com>  wrote:
>> I'm encouraging projects to make use of the naturalearth dataset for demos,
>> as these datasets are global, and hence quickstarts will not need to be
>> rewritten every year.
>> You can see which datasets are available by looking at the
>> bin/install_gisdata.sh script.
>> On 27/07/10 19:34, Johan Van de Wauw wrote:
>>> Hi all,
>>> I was expecting to find some more demo data from the region around
>>> Barcelona (especially the SRTM), and to use that one for the
>>> quickstart guide for saga gis.
>>> Are there still plans to add such files, or should/can I add my own
>>> demo file (in the install script?)
>>> (It's just a file of halve a megabyte, so size shouldn't be an issue)
>>> Johan
>>> Live-demo mailing list
>>> Live-demo at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/live-demo
>>> http://wiki.osgeo.org/wiki/Live_GIS_Disc
>> Cameron Shorter
>> Geospatial Director
>> Tel: +61 (0)2 8570 5050
>> Mob: +61 (0)419 142 254
>> Think Globally, Fix Locally
>> Geospatial Solutions enhanced with Open Standards and Open Source
>> http://www.lisasoft.com
Cameron Shorter
Geospatial Director
More information about the Live-demo
