[Live-demo] 4.0 rc5 build
Daniel Kastl
daniel.kastl at georepublic.de
Wed Jul 28 01:00:06 EDT 2010
Hi Alex,
Somehow I still have a problem with one part of the pgRouting install script
(building the sample data).
The log says (from line 4036):
create pgrouting database
add PostGIS functions
add pgRouting core functions
add pgRouting TSP functions
unpack sample data
Run osm2pgrouting converter (this may take a while)
host=127.0.0.1 user=user dbname=pgrouting port=5432
connection failed
The database is there, all required PostGIS/pgRouting funtions as well.
Last week I actually thought I found the reason and removed the initial
"sudo -u $USER_NAME" (line 120 in install_pgrouting.sh).
I tested it on the VM and when I run "osm2pgrouting" with "sudo" I get the
"connection failed" error, when I run it without it works.
I updated SVN already a few days ago, but could you make sure that
your install_pgrouting.sh was the latest one and has no "sudo -u $USER_NAME"
in line 120?
Daniel
2010/7/28 Alex Mandel <tech_dev at wildintellect.com>
> Much better, but still a few quirks:
> http://download.osgeo.org/livedvd/4.0-rc5/4.0rc5logs.tar.gz
> The Help Launcher is nowhere to be seen, the files are there the logs
> seem ok, maybe the icon shuffle at the end did it in(I looked but didn't
> see it in any of the folders)? Also Mapbender is still floating on the
> desktop.
> FYI looks like something is still making a /usr/local/livedvd-docs
> folder but all our stuff is in osgeolive-docs, someone want to find and
> kill that uneeded folder?
> Firefox homepage reset doesn't work, but that's nothing new, I did it by
> hand this time. I also added the Geospatial menu from it's file, the cpu
> monitor and the keyboard switcher so I don't forget to do it on the
> final builds.
> I'm still compressing the image to 7z, should be ready in a hour or
> less, just keep an eye on
> Thanks,
> Alex
> Live-demo mailing list
> Live-demo at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/live-demo
> http://wiki.osgeo.org/wiki/Live_GIS_Disc
URL: http://lists.osgeo.org/pipermail/live-demo/attachments/20100728/5e7362f1/attachment.html
More information about the Live-demo
