[Live-demo] Re: Which version or Java to use on the OSGeo LiveDVD?
Cameron Shorter cameron.shorter at gmail.com
Sun Jun 6 01:55:58 EDT 2010
On 06/06/10 12:05, Andrea Aime wrote:
> Mind, if you run all the java web apps in the same servlet container
> they will also start all up at once by default. That will mean a
> very long startup time and a hefty amount of memory used to start
> all the apps up (in terms of the memory needed to host the bytecode
> of each application).
Andrea,
Good point. More important than disk space is RAM usage, and speed of
starting up and running applications.
Does that mean we need to install a new servlet container for each
application?
Or is it possible to configure tomcat so that it will only upload
applications as we need them?
Cameron Shorter
Geospatial Director
Tel: +61 (0)2 8570 5050
Mob: +61 (0)419 142 254
Think Globally, Fix Locally
Geospatial Solutions enhanced with Open Standards and Open Source
http://www.lisasoft.com
More information about the Live-demo mailing list
