[Live-demo] Logs for building osgeolive-4.0alpha2
Hamish hamish_b at yahoo.com
Thu Jun 10 11:46:27 EDT 2010
> Cameron:
> > I've updated our java build script to
> > use sun java 1.6 and run the build script again
> > (re-installing over the top of 4.0alpha1 rather than
> > starting again from scratch).
Hamish:
> ?it should grep test to see if partners server is already
> in
> /etc/apt/sources.list before adding it again?
> > It seems the java applications have been installed
> now. (I
> > verified GeoServer is working).
> install_java.log:
> The following packages were automatically installed and are
> no longer required:
>   libgcj-bc libbcmail-java java-common libgcj10
> gcj-4.4-base libbcprov-java
>   libgcj-common libgnumail-java openjdk-6-jre-headless
> tzdata-java
>   openjdk-6-jre-lib libgnuinet-java
> default-jre-headless ca-certificates-java
>   libgnujaf-java
> Use 'apt-get autoremove' to remove them.
> autoremove gets run later. if you need any of these
> packages
> you will need to explicitly apt-get install them. (if
> already
> there 'install' just clears the {a}uto tag.
> > I can't see PostGIS installed. I've noticed a couple
> of
> > error messages about GDAL.
> > I haven't done much testing beyond that.
> setup.sh--------
> sed: can't read
> /usr/share/applications/ubiquity-gtkui.desktop: No such file
> or directory
> gvsig---------
> disabled in svn.
> compiling from within the scripts is not banned, if
> needed.
> but building a deb is better.
> kosmo----------
> check if symlinks exist before trying to make them
> udig------------
> wget: 2010-06-08 18:26:41 ERROR 404: Not Found.
> tar: udig-1.2-RC1.linux.gtk.x86.tar.gz: Cannot open: No
> such file or directory
> should abort script on that error.
> openjump-------------
> Archive:  openjump-v1.3.zip
> replace /usr/lib/openjump-1.3/bin/OJ.exe? [y]es, [n]o,
> [A]ll, [N]one, [r]ename:   inflating:
> should use unizip's yes-to-all command line option. (see
> install_
> opencpn.sh for example.
> apache2,ushahidi,postgre*----------
> package errors.
> start by removing half-installed gvsig pkg.
> til then all apt-get installs will abort.
> spatialite-----
> tiny wgets should use the -nv flag.
> --2010-06-09 09:54:42--  http://www.gaia-gis.it/spatialite-2.4.0/docs.html
> Connecting to www.gaia-gis.it|80.79.59.42|:80...
> connected.
> HTTP request sent, awaiting response... 404 Not Found
> 2010-06-09 09:54:43 ERROR 404: Not Found.
> still installed:  ?
> 73.582 MB
> > Logs available at:
> > http://download.osgeo.org/livedvd/4.0-alpha2/
> cheers,
> Hamish
More information about the Live-demo mailing list
