[Live-demo] 52nWPS install script
Judit Mays
mays at lat-lon.de
Wed Jun 30 08:41:52 EDT 2010
I would like to add, that you should take care to change the default
tomcat port numbers to something different, as otherwise only one
tomcat-depending application will be runable at the same time.
This does concern your http://localhost:80xx/someservice/ as well as the
tomcat connector, shutdown and redirect ports.
Please see the spread sheet linked at
http://wiki.osgeo.org/wiki/Live_GIS_Disc_Packages
for port numbers already in use by other applications.
(I am not sure the list is complete on port numbers, though...)
Kind regards,
Judit Mays
Cameron Shorter schrieb:
> Kristof,
> The tomcat provided by Ubuntu a few versions back was broken, and so as
> a consequence projects have been installing their own version of tomcat.
> You are welcome to do the same. See install_deegree.sh as an example.
> On 30/06/10 20:54, Kristof Lange wrote:
>> Hi everyone,
>> I´ve got a question concerning the tomcat6 installation out of the
>> repos on the livedvd. I tried to deploy our 52nWPS.war there but got
>> some errors.
>> SEVERE: Cannot find specific temporary folder at
>> /usr/share/tomcat6/temp..
>> WARNING: Can´t load server.xml from /usr/share/tomcat6/conf/server.xml
>> And some other files couldn´t be find. I know, that this is a typical
>> error for installations of tomcat6 out of the ubuntu-repos. My
>> question is, if I can install a tomcat from the binaries under
>> /usr/local/52nWPS/tomcat6 where I will deploy the war-archive? Or is
>> there any other common webapp-folder which will work? Otherwise I
>> think there will be some problems with multiple tomcat instances..
>> Best regards
>> Kristof L.
Desc: OpenPGP digital signature
Url : http://lists.osgeo.org/pipermail/live-demo/attachments/20100630/789fd1c2/signature-0001.bin
More information about the Live-demo
