[Live-demo] language code detection
Hamish
hamish_b at yahoo.com
Sun Sep 19 05:48:16 EDT 2010
Daniel wrote:
> At the code sprint in Barcelona we had the idea to detect the language
> code automatically by the language the user selected at login (or the
> language set by default).So Hal made a change in /bin/main.sh to read
> the $LANG parameter and set the default language (and welcome_message.txt)
> according to it. Here the additional source code:
> case `echo $LANG | sed 's/_.*//'` in
is that method acceptable for the Brazilians?
> The change for custom welcome message is in bin/install_desktop.sh (line
> 280):
> cp "$BUILD_DIR/../doc/$LANG_CODE"/welcome_message.* \
> /usr/local/share/osgeo-desktop/
> Language codes have to be added or deleted when they are ready or
> not ready to be included.
try:
if [ -e "$BUILD_DIR/../doc/$LANG_CODE"/welcome_message.txt" ] ; then
cp "$BUILD_DIR/../doc/$LANG_CODE"/welcome_message.txt \
else
cp "$BUILD_DIR"/../desktop-conf/welcome_message.txt \
fi
then if the translated version exists it will be used, otherwise it
will default to copying in the english version.
this assumes the DVD builder will be local..
original welcome_message.sh should always be copied, and duplication of
english version with desktop-conf/ is to be avoided. (correct way is to
remove the duplicated version from doc/en/, then if desired (I'm not sure
it is) 'svn move' from the desktop-conf/ dir; this way full svn history
is preserved and there is only one master file to edit. if duplicate is
absolutely needed, tell svn to use a symlink)
regards,
Hamish
More information about the Live-demo
