[Live-demo] Multi-language build working
Alex Mandel tech_dev at wildintellect.com
Mon Sep 20 00:40:52 EDT 2010
On 09/19/2010 04:12 PM, Cameron Shorter wrote:
> bin/install_main_docs.sh now builds docs for all languages (into the
> directory /usr/local/share/osgeolive-docs/ )
> You will need to either run the script as root, or make the contents of
> /usr/local/share/osgeolive-docs/ writable. (my preference is the 2nd
> option).
> Still missing:
> * The CSS for the top banner is not working any more. Alex, I wonder if
> you could help fix that.
> * We don't have buttons or flags or similar to switch between languages.
> I suspect we could write some short javascript which identifies what the
> URL is, and then switches the language (eg from /en/ to /de/) which
> would mean that you can switch from an English page to the German
> equivalent of that English page.
So do these need to be tackled before a build can happen. It wasn't
clear to me that the translation was done so I wasn't sure if I was
supposed to try building 4.1 today.
I will work on those a little tonight/tomorrow morning to see what I can do.
Thanks,
Alex
More information about the Live-demo mailing list
