[Live-demo] Re: contributor and translator files
Jorge Gaspar Sanz Salinas
jsanz at osgeo.org
Tue Sep 21 08:25:22 EDT 2010
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
El 21/09/10 14:20, Cameron Shorter escribió:
> As Hamish has picked up, I've now moved contributors and translators
> into rst format, which is not included into the {lang}/sponsors.rst wiki
> page.
> Hamish, I did consider keeping files as csv and creating rst as you
> suggest, but decided against it because:
> 1. I think our only target for our translators and contributors is for
> our documentation.
> 2. It makes creating the target documentation very easy, and we can run
> rst build using "make html" and not bin/install_main_docs.sh, which
> makes it easier for translators. I'm actually hoping that we will be
> able to have translators create their translations on windows computers
> if they so desire.
> 3. Creating rst tables from csv is not as simple as I expected, as you
> need to get each cell in a column to have the same number of chars. (so
> you can't simply do: s/,/|/ )
> If you feel really strongly about this, and want to write such a script
> instead, then go ahead.
> On 21/09/10 22:04, Hamish wrote:
>>> please keep contributor and translator files as .csv so they are easy
>>> to parse.
>> (write a script to automatically create .rst sources at build time if you
>> like, but preserve originals. no need to push through emails and osgeo
>> ids
>> to the reST version)
>> thanks,
>> Hamish
>> Live-demo mailing list
>> Live-demo at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/live-demo
>> http://wiki.osgeo.org/wiki/Live_GIS_Disc
Cameron, you can create tables in rst using CSV-like syntax
Check: http://docutils.sourceforge.net/docs/ref/rst/directives.html#id1
Example from above link:
.. csv-table:: Frozen Delights!
:header: "Treat", "Quantity", "Description"
:widths: 15, 10, 30
"Albatross", 2.99, "On a stick!"
"Crunchy Frog", 1.49, "If we took the bones out"
"Gannet Ripple", 1.99, "On a stick!"
Best
Ingeniero en Geodesia y Cartografía
http://es.osgeo.org
http://jorgesanz.net
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.10 (GNU/Linux)
Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org/
iQEcBAEBAgAGBQJMmKQxAAoJEAOYD75lvHdBi5YIAKtThBrkpxfWF+d9L0XNpCWL
9mpANqVH72cnwtzziBCgOpUiqNDgOopj3BJTCLim9vmsJbwGiReE3aHUGsXXkDYT
crwC85wb2YCOyM7gS8N7iyiA3kDac24H4l6yXgEcfUhKuY+JVWvxs/R0/QOJ37Gk
JeK/cMocPfncngeVWzQKiyAFbhR99oy8Zij9K+81bdhi5YUwStLVSR8U1bZV63bV
Xv2p/Nl6kf2nauVWW1xB1mF7012xbVChQT6ME1k7LN9AuL3PaTzYBxaeYdzgW/si
dwrxqXF0L1fy/eBjjj3LkC8aEOpPkVcj+IP7ItP10wd36nsIfY2hF+kWk7/QnF4=
=pR3k
-----END PGP SIGNATURE-----
More information about the Live-demo
