[Live-demo] allowing ssh connections
Brian Hamlin maplabs at light42.com
Wed Apr 13 12:07:28 EDT 2011
A colleague of mine and I worked on this problem further..
we removed openssh-server and the previously generated keys,
   reinstalled and re-gen'd   and it worked
The previous problem had to do with not being able to read the keys
somehow
So, no clear path to resolution, but now working here..
   -Brian
On Apr 12, 2011, at 10:55 AM, Brian Hamlin wrote:
> I have installed the LiveDVD 4.5 FOSSGIS Master onto a new machine
> using the installer option at boot time
> the machine reboots into the Live system as expected
> it is on a local network with DHCP, so it gets an address as expected
> however, when I go to ssh in from another machine, I get
>    connection closed by  <addr>
> I check that openssh-server is installed, which it is..
> hmmm... checking iptables shows no rules defined
> so I try
>   iptables -A INPUT -p tcp --dport ssh -j ACCEPT
> listing iptables rules shows the new rule, but
> now, ssh from another machine returns
>   Read from Socket failed: Connection reset by peer
> Oh Yeah - the wiki FAQ !
> so I go to .. hmm where is it?? hunt around the wiki for the right
> combination of
> Live Demo keywords
> then,  in the ssh part of this FAQ I see the part about keygen
> I build an rsa and dsa style key as shown and reboot the machine from
> the hard disk
> but still no ssh connection!?
> nmap shows ports 22  80  8009  8080  open
> So, there is something simple I am missing?
> How can I direct the new Live system to accept ssh?!
> whatever this is should *definitely* be documented
>   -Brian
> Brian Hamlin
> planetwork.net
> Live-demo mailing list
> Live-demo at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/live-demo
> http://wiki.osgeo.org/wiki/Live_GIS_Disc
More information about the Live-demo mailing list
