[Live-demo] OSGeoLive proposal to replace Sun's default JRE/JDK with custom JRE
Cameron Shorter cameron.shorter at gmail.com
Tue Aug 9 21:14:23 EDT 2011
On 10/08/11 11:12, Cameron Shorter wrote:
> On 10/08/11 09:28, Jody Garnett wrote:
>> Cameron if you were able to ensure the Sun JRE used included JAI /
>> ImageIO / ImageIO-Ext then the udig project could make use of it
>> directly (rather than using its own JRE as is done currently). An
>> easy way to check would be to use the bundled JRE from the udig
>> install script (rather than the sun jre) and see all the applications
>> still work.
>> The procedure to make one of these JRE+Extensions is here:
>> http://udig.refractions.net/confluence/display/ADMIN/JRE+for+Linux -
>> I can ask on udig-devel if they have made a script for this one yet.
>> Jody
> OSGeo-Live Java people,
> Does Jody's suggestion make sense for your project?
> Do you expect your project would work using UDig's custom java install?
> Would you anticipate we might run into any stability issues?
> Will this proposal help your project save any space?
> Any other thoughts?
> Please CC responses to live-demo at lists.osgeo.org
PS: as far as I'm aware, the list of OSGeo-Live java projects is:
52nSOS
52nWPS
52nWSS
atlasstyler
geokettle
geomajas
geonetwork
geopublisher
geoserver
gvsig
kosmo
postgis
udig
zoo-project
Cameron Shorter
Geospatial Solutions Manager
Tel: +61 (0)2 8570 5050
Mob: +61 (0)419 142 254
Think Globally, Fix Locally
Geospatial Solutions enhanced with Open Standards and Open Source
http://www.lisasoft.com
More information about the Live-demo mailing list
