[Live-demo] osgeo live documentation as a booklet/handout
maning sambale
emmanuel.sambale at gmail.com
Mon Dec 5 05:47:19 EST 2011
Testing further:
I modified the conf.py to include the following:
## -- Options for PDF output --------------------------------------------------
pdf_documents = [
('index', u'MyProject', u'My Project', u'Author Name')
pdf_language = "en_US"
pdf_break_level = 1
# Show Table Of Contents at the beginning?
pdf_use_toc = True
# How many levels deep should the table of contents be?
pdf_toc_depth = 9999
# Add section number to section references
pdf_use_numbered_links = False
# Background images fitting mode
pdf_fit_background_mode = 'scale'
Then created a new index.rst
.. meta::
:http-equiv=refresh: 0;url=en/index.html
|osgeo-live-version|
.. toctree::
:maxdepth: 2
en/index
en/overview/qgis_overview
en/quickstart/qgis_quickstart
en/overview/grass_overview
en/quickstart/grass_quickstart
This is the result: http://dl.dropbox.com/u/607635/osgeo_live/test_osgeolive.pdf
So far so good. Is this the right approach? I may have to create a
new stylesheet, but my plan is to minimize creating separate rst for
the pdf generation so that everything are in sync with osegeo-live's
documentation process. Any pointers to creating pdf template.
On Mon, Dec 5, 2011 at 5:27 PM, Hamish <hamish_b at yahoo.com> wrote:
> maning wrote:
>> Excellent! I tried creating a pdf
>> using rst2pdf. This is the process:
>> # get rst docs from svn
>> svn co https://svn.osgeo.org/osgeo/livedvd/gisvm/trunk/doc/
> try also:
> $ cd doc/
> $ make help
> Please use `make <target>' where <target> is one of
> html to make standalone HTML files
> dirhtml to make HTML files named index.html in directories
> pickle to make pickle files
> json to make JSON files
> htmlhelp to make HTML files and a HTML help project
> qthelp to make HTML files and a qthelp project
> latex to make LaTeX files, you can set PAPER=a4 or PAPER=letter
> changes to make an overview of all changed/added/deprecated items
> linkcheck to check all external links for integrity
> doctest to run all doctests embedded in the documentation (if enabled)
> $ make latex
> reading sources... [ 16%] de/quickstart/ushahidi_quickstart
> reading sources... [ 16%] de/quickstart/virtualbox_quickstart
> reading sources... [ 17%] de/quickstart/zoo-project_quickstart
> reading sources... [ 17%] de/sponsors
> reST markup error:
> .../trunk/doc/de/sponsors.rst:33: (SEVERE/4) Problems with "include" directive path:
> IOError: [Errno 2] No such file or directory: 'contributors.rst'.
> make: *** [latex] Error 1
> (so I get the similar problems as you)
> # if that had worked you could then do LaTeX to dvi/postscript/pdf,
> # with any of the classic tools.
> $ pdflatex ...
> Hamish
cheers,
maning
"Freedom is still the most radical idea of all" -N.Branden
wiki: http://esambale.wikispaces.com/
blog: http://epsg4253.wordpress.com/
More information about the Live-demo
