[Live-demo] OpenJDK Only for LiveDVD 5.5
Jody Garnett jody.garnett at gmail.com
Sat Dec 31 03:34:41 EST 2011
An easy one is to add the extensions into libs/ext and then run uDig without its "jre" folder so it uses the system default.
Geosolutions (i.e. Simone or Andrea) is the best point of contact with respect to compatibility with OpenJDK. Personally I was not going to bother until Java 7 or Java 8.
You could also try talking to Andrea Antonello who at least uses Linux and may be able to test?
If you want you can also contact me officially as "GeoTools Officer" and I will take the question to the geotools-devel email list for you. However I expect I need a more than "Open JDK" (this page for example does not give me much to work from http://openjdk.java.net/install/).
Jody Garnett
On Friday, 30 December 2011 at 9:02 PM, Cameron Shorter wrote:
> Jody and others,
> Do you know if anyone has tested the viability of using OpenJDK with JAI/ImageIO/ImageIO-EXT (with the geotools based applications)?
> What would be involved in testing this? Who would know how?
> On 30/12/11 20:29, Jody Garnett wrote:
> > Need to check out how well or poorly OpenJDK does with the JAI / ImageIO / ImageIO-EXT combo for geotools based apps.
> > Jody Garnett
> > On Friday, 30 December 2011 at 6:48 PM, Brian Hamlin wrote:
> > > jsanz tells me that GeoNetwork is also running well under OpenJDK for
> > > him
> > > let this thread be an entrypoint for Java-app contacts to express their
> > > enthusiasm, dismay, pain, resignation or otherwise on the adaptation
> > > of an OpenJDK-only LiveDVD release
> > > best regards from Berkeley, California
> > > Brian Hamlin
> > > GeoCal
> > > OSGeo California Chapter
> > > 415-717-4462 cell
> > > _______________________________________________
> > > Live-demo mailing list
> > > Live-demo at lists.osgeo.org (mailto:Live-demo at lists.osgeo.org)
> > > http://lists.osgeo.org/mailman/listinfo/live-demo
> > > http://live.osgeo.org
> > > http://wiki.osgeo.org/wiki/Live_GIS_Disc
> > _______________________________________________ Live-demo mailing list Live-demo at lists.osgeo.org (mailto:Live-demo at lists.osgeo.org) http://lists.osgeo.org/mailman/listinfo/live-demo http://live.osgeo.org http://wiki.osgeo.org/wiki/Live_GIS_Disc
> -- Cameron Shorter Geospatial Director Tel: +61 (0)2 8570 5050 Mob: +61 (0)419 142 254 Think Globally, Fix Locally Geospatial Solutions enhanced with Open Standards and Open Source http://www.lisasoft.com
URL: http://lists.osgeo.org/pipermail/live-demo/attachments/20111231/3b89b7db/attachment.html
More information about the Live-demo mailing list
