[Live-demo]Does your app work on the new OSGeo-Live V4.5 Alpha2?
Angelos Tzotsos
gcpp.kalxas at gmail.com
Fri Feb 11 17:16:54 EST 2011
Hi Cameron,
Yes, the review was done through the freenode channel by splitting the
tasks.
On 02/11/2011 01:11 PM, Cameron Shorter wrote:
> Thanks for this status. (I realise there were a number of people who
> contributed)
> I've forwarded this email onto each project contact, and have asked
> people to fix their scripts within 48 hours. After that, I think we
> should lock down the versions for all applications, and only accept
> bug fixes. Hopefully Alex should be able to create his next release
> around then too.
> On 11/02/11 10:26, Angelos Tzotsos wrote:
>> Hi all,
>> A first review of the OSGeo-Live 4.5 alpha 2 has just finished.
>> This is the list of issues that were found and commented on the
>> status spreadsheet:
>> Failure to launch:
>> 52nSOS --> The desktop link does not provide any feedback that the
>> service started.
>> Deegree --> The link does not provide any feedback that the service
>> started.
>> Geomajas --> http link not working
>> Geonetwork --> Application link not working in Firefox (service start
>> and stop links work fine)
>> Rasdaman --> Not working. Build error?
>> Sahana --> Application link not working
>> Issues with versions:
>> Deegree --> Still in 2.x version
>> GDAL --> later version (1.7.3) than proposed (1.7.2) but seems it
>> would be great to have 1.8.0
>> Geonetwork --> Version completely outdated. The installed version
>> (2.4.2) is older than the one installed in OSGeo Live 4.0.1!
>> Mapfish --> still in version 1.2 instead of 2.0
>> Openlayers --> still in version 2.9.1 instead of 2.10
>> Osgearth --> still in version 1.4.1 instead of 2.0
>> OSSIM --> installed version 1.8.3. Need to update to 1.8.6 since this
>> was used in OSGeo Live 4.0.1
>> uDig --> installed version 1.2.0 instead of latest 1.2.1
>> All applications were tested if running, but quickstarts not tested
>> in this review. Web services were tested with GetCapabilities only.
>> Regards,
>> Angelos
>> On 02/06/2011 01:50 AM, Cameron Shorter wrote:
>>> I'm looking for volunteers to help us determine which applications
>>> have been installed successfully on the latest OSGeo-Live build.
>>> In particular, we need to keep track of which version has been
>>> installed successfully.
>>> Who is available to try out applications on the latest VM? At some
>>> point, a representative from each application should run their
>>> application on the VM and confirm it works as expected. We will ask
>>> for more comprehensive testing after our UAT deadline of 21 Feb 2011.
>>> I've written up the process to follow to collect status here:
>>> http://wiki.osgeo.org/wiki/Live_GIS_Review#Application_Review
>>> Application Review
>>> * Download the latest ISO or Virtual Machine from
>>> http://live.osgeo.org/dev/build
>>> * Virtual Machines will need to be uncompressed with 7zip for
>>> windows <http://www.7-zip.org/> or 7zip for unix
>>> 7z x file.7z
>>> For each application:
>>> * Verify that you can select the application from the pull down
>>> menu.
>>> * Find out what version of the application has been installed,
>>> and insert the version number into the "installed version"
>>> column of the Status spreadsheet
>>> <https://spreadsheets.google.com/ccc?key=0Al9zh8DjmU_RdGIzd0VLLTBpQVJuNVlHMlBWSDhKLXc&hl=en_GB#gid=8>
>>> * Run the application and see if it works. If the Quickstart
>>> exists, try following the Quickstart instructions.
>>> Note any errors that you find in the issue tracker using the following:
>>> * OSGeo-Live issues are reported here:
>>> https://trac.osgeo.org/osgeo/report/10
>>> * Set "Component" = "LiveDVD"
>>> * For "Keywords", add the base release number, and the
>>> application id used in the Status Spreadsheet
>>> <https://spreadsheets.google.com/ccc?key=0Al9zh8DjmU_RdGIzd0VLLTBpQVJuNVlHMlBWSDhKLXc&hl=en_GB#gid=8>.
>>> Eg: "4.0, geoserver". Don't use "4.0rc1, geoserver".
>>> On 06/02/11 08:18, Alex Mandel wrote:
>>>> On 02/04/2011 08:33 PM, Alex Mandel wrote:
>>>>> I just started the Alpha2 build @r5513. I am well aware there are some
>>>>> known outstanding issues but since the last build only made it as far as
>>>>> Sahana we wanted to make sure that we get some error information for the
>>>>> rest of the packages.
>>>>> Look for build logs and possibly a downloadable vm in approx 12 hours
>>>>> (Build is mostly running while I'm asleep, it doesn't actually take 12
>>>>> hours, much closer to 2-3 hours).
>>>>> Thanks,
>>>>> Alex
>>>> Came out better this time, still some work to do of course. Logs an vmdk
>>>> file are up. We also now have a stable url to help you get the latest
>>>> dev build when they become available. It's a redirect for now but should
>>>> always get you to the right place.
>>>> Thanks,
>>>> Alex
>>>> _______________________________________________
>>>> Live-demo mailing list
>>>> Live-demo at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/live-demo
>>>> http://wiki.osgeo.org/wiki/Live_GIS_Disc
>>> Cameron Shorter
>>> Geospatial Director
>>> Tel: +61 (0)2 8570 5050
>>> Mob: +61 (0)419 142 254
>>> Think Globally, Fix Locally
>>> Geospatial Solutions enhanced with Open Standards and Open Source
>>> http://www.lisasoft.com
>> Angelos Tzotsos
>> Remote Sensing Laboratory
>> National Technical University of Athens
>> http://users.ntua.gr/tzotsos
> Cameron Shorter
> Geospatial Director
Angelos Tzotsos
URL: http://lists.osgeo.org/pipermail/live-demo/attachments/20110212/66257fba/attachment.html
More information about the Live-demo
