[Live-demo]Does your app work on the new OSGeo-Live V4.5 Alpha2?
Angelos Tzotsos gcpp.kalxas at gmail.com
Sat Feb 12 15:41:44 EST 2011
Hi
After more testing it seems that Sahana is working fine.
The first time I got a 404 error, but now I cannot reproduce it.
Will keep the list posted if I get new findings.
Regards,
Angelos
On 02/11/2011 01:26 AM, Angelos Tzotsos wrote:
> Hi all,
> A first review of the OSGeo-Live 4.5 alpha 2 has just finished.
> This is the list of issues that were found and commented on the status
> spreadsheet:
> Failure to launch:
> 52nSOS --> The desktop link does not provide any feedback that the
> service started.
> Deegree --> The link does not provide any feedback that the service
> started.
> Geomajas --> http link not working
> Geonetwork --> Application link not working in Firefox (service start
> and stop links work fine)
> Rasdaman --> Not working. Build error?
> Sahana --> Application link not working
> Issues with versions:
> Deegree --> Still in 2.x version
> GDAL --> later version (1.7.3) than proposed (1.7.2) but seems it
> would be great to have 1.8.0
> Geonetwork --> Version completely outdated. The installed version
> (2.4.2) is older than the one installed in OSGeo Live 4.0.1!
> Mapfish --> still in version 1.2 instead of 2.0
> Openlayers --> still in version 2.9.1 instead of 2.10
> Osgearth --> still in version 1.4.1 instead of 2.0
> OSSIM --> installed version 1.8.3. Need to update to 1.8.6 since this
> was used in OSGeo Live 4.0.1
> uDig --> installed version 1.2.0 instead of latest 1.2.1
> All applications were tested if running, but quickstarts not tested in
> this review. Web services were tested with GetCapabilities only.
> Regards,
> Angelos
> On 02/06/2011 01:50 AM, Cameron Shorter wrote:
>> I'm looking for volunteers to help us determine which applications
>> have been installed successfully on the latest OSGeo-Live build.
>> In particular, we need to keep track of which version has been
>> installed successfully.
>> Who is available to try out applications on the latest VM? At some
>> point, a representative from each application should run their
>> application on the VM and confirm it works as expected. We will ask
>> for more comprehensive testing after our UAT deadline of 21 Feb 2011.
>> I've written up the process to follow to collect status here:
>> http://wiki.osgeo.org/wiki/Live_GIS_Review#Application_Review
>>   Application Review
>>     * Download the latest ISO or Virtual Machine from
>>       http://live.osgeo.org/dev/build
>>     * Virtual Machines will need to be uncompressed with 7zip for
>>       windows <http://www.7-zip.org/> or 7zip for unix
>> 7z x file.7z
>> For each application:
>>     * Verify that you can select the application from the pull down
>>       menu.
>>     * Find out what version of the application has been installed,
>>       and insert the version number into the "installed version"
>>       column of the Status spreadsheet
>>       <https://spreadsheets.google.com/ccc?key=0Al9zh8DjmU_RdGIzd0VLLTBpQVJuNVlHMlBWSDhKLXc&hl=en_GB#gid=8>
>>     * Run the application and see if it works. If the Quickstart
>>       exists, try following the Quickstart instructions.
>> Note any errors that you find in the issue tracker using the following:
>>     * OSGeo-Live issues are reported here:
>>       https://trac.osgeo.org/osgeo/report/10
>>     * Set "Component" = "LiveDVD"
>>     * For "Keywords", add the base release number, and the
>>       application id used in the Status Spreadsheet
>>       <https://spreadsheets.google.com/ccc?key=0Al9zh8DjmU_RdGIzd0VLLTBpQVJuNVlHMlBWSDhKLXc&hl=en_GB#gid=8>.
>>       Eg: "4.0, geoserver". Don't use "4.0rc1, geoserver".
>> On 06/02/11 08:18, Alex Mandel wrote:
>>> On 02/04/2011 08:33 PM, Alex Mandel wrote:
>>>> I just started the Alpha2 build @r5513. I am well aware there are some
>>>> known outstanding issues but since the last build only made it as far as
>>>> Sahana we wanted to make sure that we get some error information for the
>>>> rest of the packages.
>>>> Look for build logs and possibly a downloadable vm in approx 12 hours
>>>> (Build is mostly running while I'm asleep, it doesn't actually take 12
>>>> hours, much closer to 2-3 hours).
>>>> Thanks,
>>>> Alex
>>> Came out better this time, still some work to do of course. Logs an vmdk
>>> file are up. We also now have a stable url to help you get the latest
>>> dev build when they become available. It's a redirect for now but should
>>> always get you to the right place.
>>> Thanks,
>>> Alex
>>> Live-demo mailing list
>>> Live-demo at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/live-demo
>>> http://wiki.osgeo.org/wiki/Live_GIS_Disc
>> Cameron Shorter
>> Geospatial Director
>> Tel: +61 (0)2 8570 5050
>> Mob: +61 (0)419 142 254
>> Think Globally, Fix Locally
>> Geospatial Solutions enhanced with Open Standards and Open Source
>> http://www.lisasoft.com
> Angelos Tzotsos
> Remote Sensing Laboratory
> National Technical University of Athens
> http://users.ntua.gr/tzotsos
Angelos Tzotsos
URL: http://lists.osgeo.org/pipermail/live-demo/attachments/20110212/7039c53c/attachment.html
More information about the Live-demo mailing list
