[Live-demo] sphinx doc build is broken
Cameron Shorter cameron.shorter at gmail.com
Sun Feb 13 03:42:50 EST 2011
I've fixed the build error, so images should be seen in the docs again.
(There was a minor RST error in 52nSOS_quickstart.rst).
On 12/02/11 16:01, Hamish wrote:
> Hi,
> I notice that the sphinx build is breaking:
> writing output... [ 56%] en/overview/sahana_overview
> writing output... [ 56%] en/overview/spatialite_overview
> writing output... [ 56%] en/overview/udig_overview
> writing output... [ 57%] en/overview/ushahidi_overview
> writing output... [ 57%] en/overview/viking_overview
> writing output... [ 57%] en/overview/zoo-project_overview
> writing output... [ 58%] en/overview/zygrib_overview
> writing output... [ 58%] en/quickstart/52nSOS_quickstart
> A build error occured [sic]. Exiting.
> Exception occurred:
>    File "/usr/lib/python2.5/site-packages/Pygments-1.3.1-py2.5.egg/pygments/lexers/__init__.py", line 80, in get_lexer_by_name
>      raise ClassNotFound('no lexer for alias %r found' % _alias)
> ClassNotFound: no lexer for alias u'shell' found
> The full traceback has been saved in /tmp/sphinx-err-880Y9L.log, if you want to report the issue to the developers.
> Please also report this if it was a user error, so that a better error message can be provided next time.
> Either send bugs to the mailing list at<http://groups.google.com/group/sphinx-dev/>,
> or report them in the tracker at<http://bitbucket.org/birkenfeld/sphinx/issues/>. Thanks!
> make: *** [sphinxbuild] Error 1
> at which point it's game over.
> see http://adhoc.osgeo.osuosl.org/livedvd/logs/
> note the nightly doc-building server is not using the version
> of sphinx as the actual disc build does. it uses a newer/buggier?
> version.
> perhaps non-ascii chars in the 52n docs are causing the trouble?
> Hamish
> Live-demo mailing list
> Live-demo at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/live-demo
> http://wiki.osgeo.org/wiki/Live_GIS_Disc
Cameron Shorter
Geospatial Director
Tel: +61 (0)2 8570 5050
Mob: +61 (0)419 142 254
Think Globally, Fix Locally
Geospatial Solutions enhanced with Open Standards and Open Source
http://www.lisasoft.com
More information about the Live-demo mailing list
