[Live-demo] Image for the GDAL overview
Hamish
hamish_b at yahoo.com
Sat Feb 26 21:05:50 EST 2011
[cc list, hope that's not a problem]
Cameron wrote:
> Have you got the source slide handy?
it's in svn next to the screenshot as the .odp (openoffice) file.
> I'm keen to strip the header image off the top of the image,
> and remove some of the white space. Also remove the grainy
> GDAL image (as we have a better GDAL image already on the html
> page).
remove or replace the image; which one?
> I'm also toying with creating a wordle image of the words.
> http://www.wordle.net/
that's a great idea.
maybe a dark/light red image on top with GDAL words.
with dark/light blue image directly below with OGR words.
take wordlist below and feed into a loop which counts google
hits for each search term to determine relative importance.
http://gdal.org/formats_list.html
http://gdal.org/ogr/ogr_formats.html
GDAL:
Arc/Info ASCII Grid
ACE2
ADRG/ARC Digitilized Raster Graphics
Arc/Info Binary Grid
AIRSAR Polarimetric
Magellan BLX Topo
Bathymetry Attributed Grid
Microsoft Windows Device Independent Bitmap
BSB Nautical Chart Format
VTP Binary Terrain Format
CEOS (Spot for instance)
DRDC COASP SAR Processor Raster
TerraSAR-X Complex SAR Data Product
Convair PolGASP data
USGS LULC Composite Theme Grid
Spot DIMAP
ELAS DIPEx
DODS/OPeNDAP
First Generation USGS DOQ
New Labelled USGS DOQ
Military Elevation Data
ERDAS Compressed Wavelets
ESRI .hdr Labelled
Erdas Imagine Raw
NASA ELAS
ENVI .hdr Labelled Raster
Epsilon - Wavelet compressed images
ERMapper
Envisat Image Product
EOSAT FAST Format
FIT
FITS
Fuji BAS Scanner Image
Generic Binary (.hdr Labelled)
Oracle Spatial GeoRaster
GSat File Format
Graphics Interchange Format
WMO GRIB1/GRIB2
GMT Compatible netCDF
GRASS Rasters
GRASS ASCII Grid
Golden Software ASCII Grid
Golden Software Binary Grid
GSC Geogrid
TIFF
BigTIFF
GeoTIFF
NOAA .gtx
GXF/Grid eXchange File
HDF4
HDF5
HF2/HFZ heightfield raster
Erdas Imagine
Image Display and Analysis (WinDisp)
ILWIS Raster Map
Intergraph Raster
USGS Astrogeology ISIS cube
JAXA PALSAR Product Reader
Japanese DEM
JPEG JFIF
JPEG-LS
JPEG2000
ECW
KAK
MrSID
OpenJPEG
JPIP
KMLSUPEROVERLAY
NOAA Polar Orbiter Level 1b Data Set (AVHRR)
Erdas .LAN and .GIS
FARSITE LCP Format
Daylon Leveller Heightfield
NADCON .los/.las
In Memory Raster
Vexcel MFF/MFF2
MG4 Encoded Lidar
Multi-resolution Seamless Image Database
Meteosat Second Generation
EUMETSAT Archive native
NLAPS Data Format
NITF
NetCDF
NTv2
Northwood/VerticalMapper Grid
OGDI Bridge
OZI OZF2/OZFX3
PCI .aux Labelled
PCI Geomatics Database File
PCRaster
Geospatial PDF
NASA Planetary Data System
Portable Network Graphics
PostGIS Raster
Netpbm
R Object Data Store
Rasdaman
Rasterlite/SQLite
Swedish Grid RIK
Raster Matrix Format
Raster Product Format/RPF (CADRG, CIB)
RadarSat2 XML
Idrisi Raster
SAGA Binary
SAR CEOS
ArcSDE Raster
USGS SDTS DEM
SGI Image
Standard Raster Product (ASRP/USRP)
SRTM HGT
Terragen Heightfield
Terralib
EarthWatch/DigitalGlobe
TerraSAR-X Product
USGS ASCII DEM / CDED
GDAL Virtual
OGC Web Coverage Server
OGC Web Map Server
X11 Pixmap
ASCII Gridded XYZ
OGR:
Aeronav FAA
ESRI ArcObjects
Arc/Info Binary Coverage
Arc/Info .E00 (ASCII) Coverage
Atlas BNA
AutoCAD DXF
Comma Separated Value (.csv)
DODS/OPeNDAP
EDIGEO
ESRI Personal GeoDatabase
ESRI ArcSDE
ESRI Shapefile
FMEObjects Gateway
GeoJSON
Géoconcept Export
Geomedia .mdb
GeoRSS
GML
GMT
GPSBabel
GPX
GPSTrackMaker
Hydrographic Transfer Format
Informix DataBlade
INTERLIS
INGRES
KML
LIBKML
Mapinfo Microstation DGN
Access MDB (PGeo and Geomedia capable)
Memory
MySQL
NAS - ALKIS
Oracle Spatial
ODBC
MS SQL Spatial
OGDI Vectors (VPF, VMAP, DCW)
OpenAir
PDS
PGDump
PostgreSQL/PostGIS
EPIInfo .REC
S-57 (ENC)
SDTS
Norwegian SOSI Standard
SQLite/SpatiaLite
SUA
UK .NTF
U.S. Census TIGER
VFK
VRT - Virtual Datasource
OGC WFS (Web Feature Service)
X-Plane/Flighgear
I'll see what I can do with 'lynx -dump' in a loop, stand by.
Hamish
More information about the Live-demo
