[Live-demo] FOSS4G GeoMoose Install Script
Cameron Shorter cameron.shorter at gmail.com
Fri Jul 1 19:34:54 EDT 2011
On 2/07/2011 3:07 AM, Bob Basques wrote:
> All,
> I (we) have an install script for GeoMoose.  See attached.  (Are we
> supposed to add to the list at :
> https://svn.osgeo.org/osgeo/livedvd/gisvm/trunk/bin/ ourselves, or ),
Yes.
You will also need to insure the script is called from bin/main.sh
Add to the END of the list of applications being installed, so if there
is a problem, you will not stop other scripts being run.
> the script is not complete (yet), but does get an instance of GeoMoose
> up and running.  Additions of the LiveDVD datasets into the interface
> still need to be built, but this should be as easy as setting up some
> MAPfiles.  Also, was wondering if there was a ledger of what is
> available on the DVD already.
We don't have a list of WMS services or similar, although that would be
a good idea.
I suggest looking at what mapserver provides, as it doesn't need to
start up a memory intensive java instance (like GeoServer).
> WMS services can be consumed by GeoMoose directly, is there a list of
> such services and/other possible services to connect to some place?
> A longer term goal is to build a .deb installer, but upon inspection
> of the details.  we've decided we need to reorganize some stuff first
> to better facilitate the .DEB building process.  This also relates
> back to the GeoMoose project in that we'll have a proper Linux
> installer to offer afterwards which is somewhat lacking right now.
> Thanks
> bobb
> Live-demo mailing list
> Live-demo at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/live-demo
> http://wiki.osgeo.org/wiki/Live_GIS_Disc
Cameron Shorter
Geospatial Solutions Manager
Tel: +61 (0)2 8570 5050
Mob: +61 (0)419 142 254
Think Globally, Fix Locally
Geospatial Solutions enhanced with Open Standards and Open Source
http://www.lisasoft.com
URL: http://lists.osgeo.org/pipermail/live-demo/attachments/20110702/ae633050/attachment.html
More information about the Live-demo mailing list
