[Live-demo] Enhancement for Version number in Online Documentation
Cameron Shorter cameron.shorter at gmail.com
Thu Jul 7 05:22:22 EDT 2011
Frank,
Checking the latest changes to the Makefile, it seems we have lost the
VERSION from the documents.
You can see a link to a nightly build here:
http://wiki.osgeo.org/wiki/Live_GIS_Disc#Documentation
to
http://adhoc.osgeo.osuosl.org/livedvd/docs/en/index.html
Are you able to look into this?
We don't have a nightly mavin build or similar automated build process
(yet). Having one could make our build process easier if someone were
able to set it up.
On 04/07/11 17:02, Frank Gasdorf wrote:
> Thanks Hamish, please have a look at the inline comments ..
> 2011/7/4 Hamish <hamish_b at yahoo.com <mailto:hamish_b at yahoo.com>>
>     Frank wrote:
>     > OK, just fixed the version read from VERSION.txt in conf.py
>     > and updated html_tilte property - in the title was still v4.5
>     > instead of the current version.
>     thanks
>     > I tried it on mac os but the arguments for sphinx-build
>     > command where not used like I thought it would. Therefore the
>     > python conf.py update to read from version file instead of
>     > parameters for sphinx-build command in Makefile
>     sphinx has been a bit of a moving target.. can you set up a
>     virtual machine in OSX to run xubuntu 11.04 in? it's the best
>     way to verify the results are the same.
> Agree, it was only mentioned to get feedback if anybody else had
> problems like this. I know, that the geotools project works with ant
> build scripts and there it seems to work but I've no idea what OS the
> build server for the docs is running.
>     also note that if the Makefile changes the nightly doc build
>     on the adhoc server stops until I validate them. (intentional
>     feature, not a bug)
> Quit interesting. Everything still all right after my changes? Is
> there a public accessible build server (hudson/jenkins) where I can
> check the build results? Is it possible to get these results to the
> mailing list?
>     > In addition I searched all 'OSGeo Live' occurrences and
>     > replaced it with OSGeo-Live.
>     it would be better to make the grep regex more robust, rather
>     than forcing all docs to use an identical version of the nom du
>     jour.
>     grep 'OSGeo[ -]Live' *.rst
> Thanks! To be exact I used the sed and searched the regular expression
> 'OSGeo.Live' and replaced it with OSGeo-Live. ;)
>     > Last but not least I updated the copyright to 2011.
>     thanks,
>     with respect to :Version: in the ReST docs header comments, I
>     would like to preserve that, it makes it easy to know if I've
>     verified that the content is still valid for the currently
>     packaged version of the software. (making it the version of
>     the software would be just as good)  that version doesn't need
>     to be exported beyond the ReST document though.
>     cheers,
>     Hamish
> Live-demo mailing list
> Live-demo at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/live-demo
Cameron Shorter
Geospatial Director
Tel: +61 (0)2 8570 5050
Mob: +61 (0)419 142 254
Think Globally, Fix Locally
Geospatial Solutions enhanced with Open Standards and Open Source
http://www.lisasoft.com
URL: http://lists.osgeo.org/pipermail/live-demo/attachments/20110707/8ea7b060/attachment-0001.html
More information about the Live-demo mailing list
