5.0alpha4 [Re: [Live-demo] 5.0alpha3 status]
Hamish
hamish_b at yahoo.com
Fri Jul 8 22:04:20 EDT 2011
just looking through the latest 5.0alpha4 build logs, here's what I notice. It seems like a number of these have already been fixed
in the last day or two; if so, nevermind..
(projects should be checking this themselves each time because
sometimes a change to something else before your installer run
may break things for you, and you know better than anyone what a
successful install log should look like)
everyone:
start at the end of the build log, and look at the collection of
error messages for anything which looks like you.
install_edutools.sh: "eric" is a fairly big package (26mb). Will the IDE
be used on the disc as part of someone's workshop?
missing desktop icons: (not found in $USER/Desktop/ after installs)
mv: cannot stat `gvsig.desktop': No such file or directory
mv: cannot stat `atlasstyler.desktop': No such file or directory
mv: cannot stat `mapguide*.desktop': No such file or directory
mv: cannot stat `*[Rr]asdaman*.desktop': No such file or directory
mv: cannot stat `monteverdi.desktop': No such file or directory
big packages to maybe-remove: (not sure if it's clean to do so)
gnome-user-guide (50mb)
smbclient (40mb) [ftp-like CLI tools]
oxygen-icon-theme (30mb) [prob just need to pick 1 theme to install]
elementary-icon-theme (27mb)
app-install-data (27mb) [alternative to Ubu Software Center in place?]
humanity-icon-theme (19mb)
xfwm4-themes (16mb)
gnome-icon-theme (11mb)
libsane (11mb)
doc translators:
991(!) occurances: (WARNING/2) Title underline too short.
-> make sure ReST underlines match subheading length
libLAS:
you're not in main.sh so not installed. should you be?
GeoMajas:
FIXME: Do not use chmod 777 if at all possible.
uDig:
http://udig.refractions.net/files/downloads/udig-1.2.2.html:
2011-07-06 15:00:06 ERROR 404: Not Found.
openJump:
FIXME: don't use wget for local files, just copy from local svn checkout.
gvSig:
E: Unable to locate package gvsig
(seems fairly major)
osm: (no action required?)
osmarender breakage due to temporary DNS error on Alex's build machine?
pgRouting:
osm2pgrouting is very noisy. can anything be done about that?
Sahana:
python: no process found
dropdb: database removal failed: ERROR: database "sahana" does not exist
(but that's just pre-emptive cleanup, so ignore, right?)
wants celery installed?
File "web2py.py", line 19, in <module>
gluon.widget.start(cron=True)
File "/usr/local/lib/web2py/gluon/widget.py", line 808, in start
import_models=options.import_models, startfile=options.run)
File "/usr/local/lib/web2py/gluon/shell.py", line 200, in run
execfile(startfile, _env)
File "applications/eden/static/scripts/tools/compile.py", line 33, in <module>
compile_application(folder)
File "/usr/local/lib/web2py/gluon/compileapp.py", line 506, in compile_application
os.mkdir(os.path.join(folder, 'compiled'))
OSError: [Errno 13] Permission denied: 'applications/eden/compiled'
addgeometrycolumn
Ushahidi:
tar: A lone zero block at 17095
ERROR 1045 (28000): Access denied for user 'root'@'localhost' (using password: YES)
...is that anything to worry about?
Mapfish: (not really sure how many of these matter)
...some download errors
Getting distribution for 'cssmin==0.1.4'.
warning: no previously-included files matching '.DS_Store' found anywhere in distribution
(Mac?)
... (many more)
dropdb: database removal failed: ERROR: database "v2.2_mapfishsample" does not exist
R-stats:
The following packages have unmet dependencies:
r-cran-vr : Depends: r-cran-mass but it is not going to be installed
Depends: r-cran-class but it is not going to be installed
E: Broken packages
ERROR: dependency 'graph' is not available for package 'RBGL'
ERROR: configuration failed for package 'rggobi'
Ossim:
(probably fairly major breakage, only gdal 1.6.0 and 1.8.0 are avail)
E: Unable to locate package libgdal1-1.7.0
E: Couldn't find any package by regex 'libgdal1-1.7.0'
E: Unable to locate package libgdal1-1.7.0-grass
E: Couldn't find any package by regex 'libgdal1-1.7.0-grass'
tar: ossim/quickstart: Cannot open: File exists
tar: Exiting with failure status due to previous errors
WARNING: timestamping does nothing in combination with -O. See the wget
manual for details.
./install_ossim.sh: 175: ossim-img2rr: not found
chmod: cannot operate on dangling symlink `/usr/local/share/ossim/ossimPlanetUsers.pdf'
52nSOS:
mv: cannot stat `/tmp/build_52nSOS/52nSOS.war': No such file or directory
chown: cannot access `/var/lib/tomcat6/webapps/52nSOS.war': No such file or directory
otb:
(probably fairly major breakage)
E: Unable to locate package otb
cp: cannot stat `/usr/share/applications/monteverdi.desktop': No such file or directory
chown: cannot access `/home/user/Desktop/monteverdi.desktop': No such file or directory
Rasdaman:
---always add svn commit log messages, please---
(probably fairly major breakage; now fixed?)
... http://www.rasdaman.com/Download/rasdaman_2011-03-17.tgz
2011-07-06 18:21:25 ERROR 404: Not Found.
tar (child): rasdaman_2011-03-17.tgz: Cannot open: No such file or directory
tar (child): Error is not recoverable: exiting now
tar: Child returned status 2
tar: Error is not recoverable: exiting now
cd: 62: can't cd to rasdaman
./install_rasdaman.sh: 65: ./configure: not found
make: *** No rule to make target `install'. Stop.
ERROR: package install failed.
pycsw:
the wget manual for details.
pywps:
"export FOO=bar" in wrapper script is a Bashism.
Use "FOO=bar; export FOO" instead.
install_gisdata.sh:
Starting AtlasStyler...
log4j:WARN No appenders could be found for logger (org.geopublishing.atlasStyler.ASProps).
log4j:WARN Please initialize the log4j system properly.
Not starting GUI because command line parameter addFix was passed
(many of these)
install_language.sh:
E: Unable to locate package xfkc (no longer exists, do we need to find an alternative?)
zh -> chose simplified instead of traditional. ok?
tinyows:
put XML setup into /usr/local/share/tinyows/ and not /etc?
thanks,
Hamish
More information about the Live-demo
